Thread: Need advice...salt water or ozone & nature 2
    We just brought a pool and are very confused on what system to use. After reading a lot of threads it seems like most people choose salt water systems. Our salesman has strongly recommended ozone and nature 2 together. Thought????
    24' Round AG Vinyl Pool (13,500 Gallons)
    Sand Filter, Aquabug Vacuum
    Pump Size: ?? Flow Rate:??
    Shifted from Baquacil to Chlorine 8/2011
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Need advice...salt water or ozone & nature 2
    Welcome to TFP!
    The saltwater system uses the salt to generate chlroine which serves as the primary sanitizer. The ozone system and the Nature 2 are both supplemental systems. The Nature 2 doesn't do anything beyond what chlorine alone does, and adds the risk of staining the pool and swimmers' hair and fingernails green.
    Ozone does give added benefits, but the extra cost is usually not worth the benefit unless you have a lot of guests in your pool. Ozone can help eliminate contaminants and is more effective than chlorine on a couple of human transmitted organisms, but for most people, the risk of ever having those organisms enter their pools is slim.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Go with a chlorine sanitizer system. Then decide if you want to use liquid bleach, or install a SWCG. There are pros and cons to both. Let us know your choice.
