Thread: Blue Haven Smartpure Sanitizer inspect cell/low salt light
    Jul 2011
    Greenwood, Indiana
    42
    We run our pump 24/7 and have our SWG turned up to 70-80% and now inspect cell and low salt lights are on. We've added a lot of salt, more than usual and it still says low salt. I'm guessing it's gone bad. This is our 3rd season in this house, so I'm guessing it's reached it's max life, not sure how old it is. So, do I need to replace the entire SWG unit? We've inspected and cleaned the cell ourselves and even let the dreaded pool store check it and it is clear. Anything else I should do before throwing in the towel and buying new? I'm tempted to just add chlorine manually the rest of the season and bite the bullet in the spring. We have about 4 or 5 good weeks of swimming left, but the kids are already back in school, so swimming mainly weekends only. Any tips on that?
    Thanks!!
    Kim
    18,000 gallon in ground SWG sand filter electric cover
    Oct 2010
    Georgia
    317
    Re: Blue Haven Smartpure Sanitizer inspect cell/low salt lig
    Kimmisue
    Symptoms suggest a failing salt cell.
    Did the pool store "test" the cell?
    You should be able to replace just the cell.
    Blue Haven smartpure systems are private label branding by Hayward/Goldline and is the same system as the Aquarite.
    What is the model number on the salt cell?
    Manually adding chlorine for a few weeks is simple.
    pool-school/types_chlorine_pool
    PSG
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Jul 2011
    Greenwood, Indiana
    42
    My husband said they did test the cell and it was working.....so......maybe not the cell? What else can I check?
    I have the same situation. Store test shows the water is balanced and the salt is ~3300ppm. But the Smartpure panel has inspect cell and low salt lights on.
    How did you guys fix the problem?
    My strip test says the slat is ~3300ppm, but the panel reading is 2.1, and the inspect cell and low salt lights on. There is another thread talk about the similar situation, it doesn't talk how they fix it either. Anybody can help? Thank you in advance
