Results 1 to 10 of 10
Thread: New gas pool heater full of scale
    We have a gas pool heater that is less than 2 years old. We started having trouble with it knocking. 1000 dollars later it is working. The first issue that was identified was that the plumbing was wrong. The water was going in the heater at the out port and out of the heater from the in port. The pool installer came and fixed this issue. The heater continued to knock. So then the bypass spring was replaced as well as the thermostat. Still knocking. Last they ordered a kit to clean everything and replace some of the rings, etc.. The heater repair man cleaned out lots of scale. Now my heater works!
    Why would I have so much scale in less than 2 years (we use the pool year-round)? Could it be the plumbing reversed? Could it be that I have hard water? What can I do to prevent this from happening again?
    Thanks for your help!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    Re: New gas pool heater full of scale
    Could you post a complete set of water test results? That will help us figure out what is going on.
    Thanks!
    FC 4.5
    CC 0
    Ph 7.5
    TA 70
    CH. 220
    CYA 40 ( I am always uncertain with this. I second guess myself about the block dot disappearing.)
    Another problem for me is CH. It usually goes purple befor it turns blue and it is hard for me to find that exact change.
    Dory
    East TN
    Raypak Gas Heater
    There is nothing about your current water numbers that suggests any chance of scaling problems, which leaves a bit of a mystery. Your water chemistry could have been worse in the past, and the scaling could have happened then, but then there wouldn't be any reason for the knocking to have started recently. Another possibility is that your CH level is actually much higher than you think it is, though that seems unlikely.
    The water inside the heater is hotter than the water in the pool, and hotter water is more likely to cause scaling, but even so your CH level would have had to have been over 400 at some point to have any significant chance of scaling.
    Having the CH test turn purple is called a floating end point and can cause invalid test results. If this happens, do the test again, but this time add five drops of R-0012 before adding any R-0010 or R-0011L. Remember to count the initial five drops in the total.
    Thanks for your help! So if I add 5 drops of R0012 first will it go from pink to blue without going to purple making it easier from me to get the correct level?
    East TN
    Raypak Gas Heater
    Ft Lauderdale, Florida
    1,455
    You would need to look at a historical data plot to determine if water chemistry may have caused the scale formation, rather than a snapshot.
    If your calcium hardness, total alkalinity, or pH were kept on the higher side are any duration of time, that would haave caused scale to build up. You wouldn't happen to have your past years test results would you?
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    30,408
    I am not being particularly helpful, but I'm fairly certain I remember that "knocking" in a hot water heater is a direct indicator of scale. I do not have experience with a pool heater but the idea is the same.
    Mar 2011
    441
    The knocking is indicator of low flow. The low flow could be because of scale, or low flow.
    Reversing the inlet/outlet ports can cause scaling on Raypak/Rheem, and Pentair/ Sta-rite heaters.
    20X40 30,000 gallon gunite pool
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    I see from your signature that you have a SWG. There is a formula in the manual for my SWG that helps you figure out whether or not scaling can happen by figuring out the saturation index. I haven't done this formula yet but I'm going to try it. The formula is on Page 5 here:
    http://www.hayward-pool.com/pdf/manuals/Manual239.pdf
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Thank you so much for all the replies! Now that I have my Taylor K2006 test kit, I am getting more accurate results. The kit includes a wheel for calculating the SI. For the first year, I used test strips and pool store results. Thanks to the advice from this forum, I am doing better. Hopefully, my heater problems are over!
    East TN
    Raypak Gas Heater
