Results 1 to 8 of 8
Thread: Rust - Now what do I do?
    Shelley N's Avatar
    Denver, Colorado
    199
    The picture says it all... Now what do I do?
    [attachment=1:15y9vrsh]pool 001.jpg[/attachment:15y9vrsh]
    [attachment=0:15y9vrsh]pool 006.jpg[/attachment:15y9vrsh]
    Shelley
    Denver, CO
    22,551
    Re: Rust - Now what do I do?
    If it's superficial you can wire brush it off and rust-oleum it. If it's through the wall you'll have to drain and repair or replace that section of the wall.
    Western Pennsylvania
    151
    I would think that carpeting is causing the rust as the sun cant dry out the ground.
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    Shelley N's Avatar
    Denver, Colorado
    199
    It stays wet there as that's where we drag the cover off daily. I'm really regretting adding salt those two years I tried it. I really feel kinda of screwed as the track looks really bad to me. I wonder what it looks like on the side that's under the deck.
    Shelley
    Denver, CO
    Jul 2011
    Lehigh Valley, PA
    163
    wow. As someone who just got a new AGP(steel) with a new SWG(intex), this is really making me have pause when using a SWG. Has anyone else had this problem ?
    21' All Steel AGP with Resin caps, Heyward S244T Sand Filter, Heyward 1HP 2 speed pump
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I suspect it's that carpet and water and not specifically the salt, I don't believe the salt content is high enough to specifically cause rust in/of itself. Bottom line is that steel + water eventually = rust.
    The place where I pull off my solar cover is pretty much always wet as well.
    30,426
    water touching metal is not good for the metal.....ever. The salt may contribute but water needs to be kept away from metal or allowed to dry thoroughly.
    Same as water lingering around wood....something bad is going to happen sooner or later.
    Shelley N's Avatar
    Denver, Colorado
    199
    I haven't dragged the cover off that end for the week and it remains wet about 6" out constantly. If we have a leak (which I really don't think) the water level isn't dropping. I'm wondering if it may have something to do with 95 degree days with 58 degree nights and sweating.....?
    Shelley
    Denver, CO
