Thread: Once the green turns cloudy blue.
    So once my green turns cloudy blue should I continue to keep it at shock level?
    Tulsa, Oklahoma
    13,000
    SAND
    AG
    Mar 2010
    Spring, TX
    1,082
    Re: Once the green turns cloudy blue.
    Quote Originally Posted by TulsaMary
    You should continue to shock until you pass the oclt in pool school. If you let up and have not pass the oclt the process will start over.
    So continue to shock as you would, do the oclt pool-school/overnight_fc_test until you pass then you can stop shocking. This is very important part of the process.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes indeed, you are just part of the way through now. Soon it will be clear!
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    The worst is over..............don't quit now.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by mynewpool
    There are three criteria to determine when you are done shocking. See red lines in my sig.
    You're done SLAMing when:
    Blue is better than green, for sure. But you still need to get to clear water. The white stuff is dead algae, but there can still be some living algae in there too, so you want to keep the chlorine at shock level. Keep brushing and running the filter 24/7. Brush any nooks and crannies where algae can hide out. Keep the pool clean, no leaves on the bottom or in the skimmers, wash the filter if it needs it.
