Sorry to hear that. How is he doing now?bobjdan said:It was pretty bad last night.
Don't trust the pool store results...lots of examples on here where they are wrong. Take a look at the extended directions for measuring CYA and see if that helps:http://www.troublefreepool.com/extended-test-kit-directions-t25081.html#p206397. Especially note doing the test with sun and your back to the sun.bobjdan said:So when I checked the pool at 6:30 this a.m. my FC was 16 (21 last night at 8 pm) and CC was 0. I went to the pool place today at about 10:30 and he said my CYA was 10, my chlorine 8, and my PH 7.5. So I just got done checking my pool at 1:15 and it read FC 14, ph 7.5 and CYA 30! My wife got the same CYA reading. The other day when I checked it after straining it through a coffee-filter my best guess was around 45 but absolutely not below 40 so I'm confused. The only difference I can think of is that I had added about 1.5 inches to the pool on Wednesday and I had used a new unopened bottle of R-0013. The previous bottle had been opened in April or May for a test, then last Saturday, and earlier this week.
Test your CYA again after reading the above link and use that for the FC level. If it is 30, I would stay above 13 at all times...except maybe let it drop to 13 when swimming. I am surprised he had such a reaction at 21 ppm, but a good rule of thumb that is said here often is only swim in water that is "up to" shock level.bobjdan said:With my CYA at 30 the calculator says that for shock it should be at 13 so I guess that is why my grandsons eyes were burning at 21. I tried for 20 and measured the chlorine so my pool must be a bit short of 25000 galllons. Then again that's like a rounding error. So what level do you think I should keep the chlorine at until the algae is gone? 16?
