Results 1 to 7 of 7
Thread: Which colour liner for best heat collection in the water?
    Jul 2011
    SW France
    105
    Just pondering....;
    Which is the best colour liner for putting the sun's heat into an outside pool?
    I have two thoughts;
    Black absorbs the most light and sun - does this mean that the water does not get hot because the liner has absorbed it?
    Cream coloured - does this reflect the heat back into the water?
    Or is it the other way around?
    I'm sure there's a clever person out there who has the answer...
    SWG - Exterior
    12x5M
    90,000 Ltrs /24,000US gallons
    Pool Pilot Digital
    Hayward Max Flo VS
    Polaris 280
    Vinyl liner
    Sand Filter
    Re: Which colour liner for best heat collection in the water
    Darker liners keep the water warmer. Lighter colors reflect more light back out of the pool.
    Jul 2011
    SW France
    105
    aha...but here's another thought for the day;
    Black clothes absorb more sunlight and heat radiated from the body than white clothes. However,if they are loose-fitting, and there is wind, the wind convects the heat away faster than it is absorbed. White clothing reflects sunlight, but also reflects internal heat back towards your body, so the net effect under identical conditions is less cooling than with black clothes.....
    QED if you have a black liner it will hold the heat, but not disperse it to the water, but a white liner will reflect the heat straight back into the water = warmer water.....
    SWG - Exterior
    12x5M
    Pool Pilot Digital
    Hayward Max Flo VS
    Polaris 280
    Vinyl liner
    Sand Filter
    Thermal transfer between the liner and the water is extremely efficient, totally unlike the clothing situation where there is an insulating air gap.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Yup ...also you may strongly consider a dark blue liner vs. black. I believe (may be mistaken) but depth perception is a big issue in black liner pool. I guess that's only a concern if it is a diving pool though
    tgmb's Avatar
    Jul 2011
    san jose, ca.
    92
    Richard,
    I switched from a very light, almost white plaster to a dark Mediterranean blue, and my average unheated temp rose about 5 degrees F. Tom
    20k gal. 36' In ground Med. Blue plaster, two-speed EcoPump EP6, Pentair 3.14 sq. Ft. Sand w/zeosand, Spectralight SL 500, RayPak 2100 heater, Polaris 360,GE Timer 15087, Borates 80 ppm.
    Jul 2011
    SW France
    105
    Tom,
    it seems that you have the "proof in the pudding" as it were....
    thanks everyone.
    SWG - Exterior
    12x5M
    Pool Pilot Digital
    Hayward Max Flo VS
    Polaris 280
    Vinyl liner
    Sand Filter
