Thread: Pool water
    Pool water
    I am draining water from my pool because my CYA is too high. Is it OK to fill it back up with well water?? I has that "sulfur" smell, but otherwise it is OK.
    Thanks
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pool water
    Do you know if you have metals in your water? They can cause colored water and staining. Chlorine will take care of the sulfur smell.
    You can test by putting some of you well water in a white 5 gallon bucket, then put chlorine in it to raise to shock level and observe if the water changes color/tints.
    Sep 2009
    Greentown, IN
    914
    Re: Pool water
    linen is right, the biggest concern w/well water is the metals that could be in it. You can run it through your softener if you have one but you will likely need to recharge it several times.
    It is also extra wear and tear on your softener.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
