Thread: Add too much FC reagent for FAS-DPD
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Will adding to much 0871 (FAS-DPD reagent) throw the results off when I add the 0003
    (CC reagent)? I was testing for FC and after 10 drops the solution APPEARED clear, but I wasn't sure so I added another drop. There was no change and then I checked for CC and got a solid zero.
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Re: Add too much FC reagent for FAS-DPD
    Using extra drops in the FC phase, beyond what is actually needed, will cause the test to read CC lower than actual, assuming CC is above zero.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    That's what I was afraid of. I usually get a small CC reading, this time it was clearly zero.
    10,800 gallons
    TF-100 Test Kit
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    I forgot to ask: If I'm not sure that all the pink is gone, should I add another drop? Which direction should I err?
    Thanks again
    10,800 gallons
    TF-100 Test Kit
    If you aren't sure if the pink is completely gone on the FC phase, add one more drop. If the color does not change count that drop as a CC drop.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    OK, I see what your saying, thanks!
    10,800 gallons
    TF-100 Test Kit
