Thread: Sit n spa jet question
    I have what I think is called a "sit n spa" on the side of my pool. It has 3 jets and an air inlet on top.
    We just used it for the first time this year, and when I open the air inlet, water comes out. It was functioning fine last year.
    Thinking that there is a blockage, I checked the jets. Water is coming out the jets evenly and strongly.
    I tried to adjust the angle of the jets, and they would not move. I am able to rotate the nozzle, but just not angle it.
    I'm suspecting that my pool company put the wrong jets in when they opened the pool, but before I call them back (there will be a service charge, I'm sure!), I wanted to investigate / diagnose it myself.
    I'm not 100% sure, but my jet does look something like this:
    http://www.spadepot.com/shop/F-S-Manifo ... 3C693.aspx
    I'd like to try to take it apart, but I'm not sure how.
    Any thoughts would be appreciated!
    /greg
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Sit n spa jet question
    Your jets should push water. The valve you show has a air line for a venturi, that requires the valve/dial for the air line to be open, and will bring bubbles into the spa with the water it is bringing. I would if your air valve is shut or if you system requires a blower, and it is not on?
    Quote Originally Posted by linen
    Sorry - what I meant was this jet looks like mine on the outside. I don't know how to take it apart, so I don't know what it looks like on the inside.
    Point is... The spa worked fine last year, and now water is coming out the air intake. I'm wondering if the pool company, when opening the pool, put the wrong nozzle or something, causing not enough flow? Although, the water coming out the jets is strong on all three.
    /greg
    Bump... Hoping someone can provide some more info on my problem.
    Thx!
