Thread: Leaves in Polaris 380 In-Line Filter
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    I'm getting leaf debris in my in-line filter. It's not unusual to get bits of grit, like grains of sand, trapped in the filter. This year, though, I'm getting relatively large bits of leaves, debris that I think should be trapped by the pool filter. Lately, the in-line filter needs to be cleaned at least twice per week.
    This is a typical Polaris installation - water goes from the pool filter directly into the Polaris booster pump and out to the 380. My in-line filter is the older model that is contained inside the quick disconnect with universal wall fitting assembly.
    I'm thinking that this isn't a Polaris problem, but a pool filter problem. As you can see in my sig block, I'm using a Hayward S-244 w/Zeolite. Filter & media are both less than 3 seasons old.
    Any thoughts?
    Thanks!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    22,553
    Re: Leaves in Polaris 380 In-Line Filter
    If you're getting debris that you can see, past the filter there's definitely something wrong with the filter. Are you getting any Zeo in the pool?
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    ... Are you getting any Zeo in the pool?
    Nope. I see some Zeo when I backwash - more like Zeo dust.
    TF-100 test kit.
    22,553
    Then I'd suspect the multiport valve and/or gasket.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Boogers. Well, I know how to check/replace the gasket. Guess I'll try that before I fool with the multiport.
    TF-100 test kit.
