Thread: Brownish stains in cement pool
    Hi.
    Just opened the restored cement pool last Sunday and I have a question about brownish staining.
    My Calcium hardness was low for the first few days at 40 ppm as I did not have a test kit to test it. I add Calcium Cloride yesterday and brought it up to 160ppm, which the high end of where my salt machine booklet says I should be, but low from what I see in other documentation. I've now tested for Alkalinity and it's at 40ppm.
    The Calcium Cloride was added yesterday so I should be okay to add the baking soda today.
    I'm pretty sure that the brown staining just below the pool tiles and on the white returns and skimmer is due to metals. Can the pool store test my water for metals?
    We’re not on a well but I’m pretty sure that we have Iron in our cities water.
    Is there a way of getting rid of the stains once the problem is found and resolved?
    Clorination has been taking place with the SWG since Monday.
    FC 1.8
    TC .2
    Calcium hardness 160
    Alkalinity 40
    PH 7.5
    Pool 12000 gallons.
    Thanks
    Cement 12'x30', in the neighborhood of 50 years old. Restored, 1.5"plumbing, 1hp super pump 2, Hayward swim clear cartridge filter, Summit2.5t heater,Hayward SWG t-9 cell, Nexxus Blanco lights, pentair bermuda gunite skimmer.
    22,549
    Re: Brownish stains in cement pool
    Your pool store should be able to test for metals, but don't take a negative result as proof. You can also get a water report from your utility (most have them online now) and find out what's in the fill water.
    You can try a vitamin C tablet on the stains to see if it lightens them. If it does they're metal. An AA treatment will get rid of them or if it's just in a few places, spot treating them might be better.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Does acidic acid mean that we lose use of the pool for a few days? Can it wait until the end of the season?
    We just got in
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by brownsburg
    We just got in
    You can certainally wait 'til after swim season to do an AA (ascorbic acid) treatment. No problem.
    You should concentrate on balancing the pool chemistry. The FC is too low and your SWG may not be keeping up. You should use bleach/liquid chlorine to help maintain FC until you get the SWG dialed in.
    What is the CYA number?
    TA and CH are too low. Adjust TA up to about 70 first, then wait a day or so and then adjust CH.
    You're done SLAMing when:
    Quote Originally Posted by Butterfly
    We just got in
    For FC I find 1.8 to be perfect. It's mid way between the recommended 1-3ppm
    CYA is too low to be read with my kit, below 20. This is appearantly normal for SWG systems.
    TA will be brought up this evening, CH will be increased on the weekend.
    By AA treatment, did he mean directly in the water or drain, wash, fill?
    Thanks
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Not normal. You better check your swg user manual, I am seeing 60-80 ppm CYA, with 80 being "best".
