Results 1 to 8 of 8
Thread: Question about adding bleach
    Mar 2010
    Spring, TX
    1,082
    There have been a few times recently that when I add bleach, it seems to bubble up to the top of the water and float around the pool. Usually when I pour it in, it goes straight down and is pushed away by the returns and never bubbles up.
    Could this be a sign of bad bleach? The only reason I ask is last time it did this, I had an unusual amount of FC loss. I have checked for OCLT and pass with flying colors so it is not that.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Aug 2010
    Dallas, TX
    4,052
    Re: Question about adding bleach
    I know when you bring a pool up to shock level when organics are present, you will see bubbling pretty often. Can you post a full set of test results? Do you have CC present?
    22,553
    You're not using one of the speciality bleaches are you?
    30,431
    Bleach is heavier than water and I have never seen it float or bubble up.
    Mar 2010
    Spring, TX
    1,082
    Just regular bleach. I can post a full set of results later. I very rarely have any CC, if I do it is only .5 or less.
    Mar 2010
    Spring, TX
    1,082
    I will try to take a picture next time.
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by RobbieH
    FC: 2.5
    CC: .5
    TC: 3.0
    pH: 7.8
    CH: 300
    TA: 120-130
    CYA: 30
    I am adding a lot of acid every 3 days or so to keep pH down, but the TA does not seem to really be dropping. Is that because I am not being as agressive with dropping it since I am only adding acid every 3 days or so? I remember when I had it at 90 pH would hold for like 2-3 weeks.
    Thanks.
    Mar 2010
    Spring, TX
    1,082
    Also I just noticed this morning that some of the tiles have fallen off of the side. Is there a way to put there back on?
