Thread: Ascorbic Acid question
    Jul 2011
    Canton, MI
    47
    I'm planning on doing the ascorbic acid treatment to remove some iron stains, before I close my pool in September. I live in michigan so the water that is left in the pool over the winter will freeze. The water will be drained below anything in the pool that contains metal (screws, skimmer opening, return opening, etc.) Is it possible for the iron stains to re-form over the winter when the pool is covered, and be visible next spring when I open the pool?
    17,500 gallons, Vinyl, Above ground, Hayward Sand filter, Hayward 1.5hp pump
    Re: Absorbic Acid question
    Yes, it is possible, though not likely. Stains tend to form when the PH gets too high. That happens to a few people over the winter, but is rare, and can't happen when the pool is completely frozen.
    Jul 2011
    Canton, MI
    47
    Thanks. Any Idea how long the stain removal process takes from start to finish? Just trying to figure out when I should start. Also, is it better to do it now when it's warmer, or should I wait until sept. when it's a little cooler? I'm a little hesitant to do it now because there's not much swim season left here, and I know the process might take a while. I'm also concerned about lowering the FC to near zero when it's 85 degrees.
    Ladeda's Avatar
    Jun 2010
    Munford Tn
    15
    Re: Ascorbic Acid question
    From my experience it depends on how dark the stain is. I have had minimal staining disappear over night and not so minimal staining take almost 48 hours. Either way, it really works well. I have a 25000gal pool. I have done the absorbic acid process without lowering FC. I was told that the reason for lowering FC was that it burned up most the product before it would work thoroughly. It actually worked well and I used half the amount. I found the Stain Free granular brand of absorbic acid thru Amazon for half the price - Also other products like metal out. Good luck.
    25,000 gal IG Liner - Filter Sand Z Brite - Pump 5 HP - TF-100 test Kit
