Thread: A story
    Gulf Coast, AL
    61
    A story
    So, I had a huge amount of pollen in the pool.
    Gathered on the floor like the sands of a desert and stuccoed the sides like an adobe hut.
    It truly was a sigh to behold.
    After an hour and a half of painstakingly vacuuming the sides and ever so slowly and delicately
    sweeping the bottom as to not disturb the pollen at rest, I once again had a clean, crystalline pool.
    The torrent of pollen caused the sand filter pressure to rise some 8 lbs.
    Since I had DE in the filter and am abounding in wisdom, I decided I would wait until the next rain storm to get the pool level up then give the filter a nice long backwash.
    As we know, a sand filter can catch particles down to 30 microns or so.
    Did you know there a large a lot of pollen types that are smaller than 30 microns?
    Well, I didn't.
    The next day I came out to enjoy my sparkly, polished pool and instead was greeted with the Sahara Desert.
    I was more than a little sad.
    The filter pressure was right back in the normal operating range.
    The pollen looked to be more evenly distributed that before I vacuumed.
    I guess that means I've got pretty good circulation.
    16x32 Grecian, vinyl liner, IG, 19000 gal.
    1.5 h.p. Hayward Super Pump 2 speed. Hayward S244T sand filter
    Circupool RJ45 SWG, TF100
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: A story
    Oh, that stinks! Its such a pain when you work really carefully and it still all falls apart.
    Love TFP? Become a
    TFP Supporter!
    Apr 2011
    Lynchburg VA
    393
    Re: A story
    If nothing else it's a good lesson for all of us. When you are done vacuuming, backwash that sand filter. Im going home to do mine right now.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jun 2008
    Marana, AZ
    347
    Re: A story
    Dust particles are also often smaller than 30 microns. Living in the desert I've got a lot of it! Never seem to be able to keep the bottom of the pool clean!
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
