Results 1 to 17 of 17
Thread: Newbee Needs Pump Help Fast
    Hi, I am new here.
    I recently bought a house with a pool and i am having pump issues. Barely know anything about pools so bare with me. Here is my general setup:
    -In ground pool in Florida 14,000 gallons
    -One main pump (that's what I call it) and the sticker in the side says 1.5 HP
    -One secondary pump that appears to control the self pool cleaner. The label is faded but it looks like it is the same size as the main pump. Both motors are on separate timers.
    -Sand filter and salt chlorine generator
    Problems:
    The main motor has been starting and stopping when it is supposed to be on. Nothing is tripping, it just comes on and off by itself in 10 to 30 minute cycles. It looks old and it is loud when it runs.
    The secondary pump is quite loud when it is on.
    You can click on the link below for photos. They are pretty clear.
    http://tylerreese.smugmug.com/Other/...264594_w7pSGpv
    I assume I need to change both motors? Any thoughts? Can I just buy one more powerful unit instead of having two? What pumps do you recommend? I don't mind spending extra if it will save on electricity. Please help!
    Jason
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Newbee Needs Pump Help Fast
    The timer it is connected to could be bad. Does the pump seem to be overheated when it cuts off? The noise is likely due to the age of the pumps. Unless the noise on the booster pump is bothersome, I would keep the pump and save for a replacement. You could run an auto cleaner off the main pump, but that would also involve re-routing some plumbing. In my opinion, you would be better off replacing the main pump with a 1 hp 2 speed pump, if it turns out you need a new pump. For everyday filtering you run it at low speed and for vacuuming use high speed. Low speed will save energy costs and run more quietly.
    Love TFP? Become a
    TFP Supporter!
    The booster pump for the auto cleaner is usually a 3/4 HP and it should only be on while the main pump is running.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
    Quote Originally Posted by zea3
    I think the main pump is overheating because is gets super hot. It that the motor or the timer?
    Quote Originally Posted by Dalandlord
    The auto cleaner doesn't rally work any way so I have it taken out right now.
    _________________________________________________
    Any 2 speed pump recommendations? Can I just leave the booster pump off since i am not using the cleaner? (I vacuum myself).
    Should I stick with a 1.5 HP 2 speed pump for the main?
    Jul 2009
    Houston, Texas
    9,376
    If the pump is shutting down because it is overheating then that would be the motor.
    Love TFP? Become a
    TFP Supporter!
    22,542
    Just reinforcing what Zea said. You could probably just replace the motor on the pump you have with a 2-speed motor or just replace the pump with a 1 hp 2-speed pump. That would be plenty big for your pool. I'd leave the booster pump alone until it had to be replaced and then decide if you want to stick with a pressure side cleaner or convert to a suction side and get rid of the booster all together.
    So is the overheating the motor of the timer? The pump is 1.5 HP This may be a stupid question but should i get a 1.5 HP two speed pump?
    Thanks for everyone's help.
    Jul 2009
    Houston, Texas
    9,376
    Quote Originally Posted by slambrecht
    No, the motor is malfunctioning and causing the overheating. The timer is not part of the motor. You can buy any size pump you want, but you don't need a 1.5 hp. A 1 hp 2 speed will save you some energy costs and still have plenty of power for your pool. Slower moving water will filter more efficiently, so we tend to advocate slower pumps and bigger filters.
    Love TFP? Become a
    TFP Supporter!
    22,542
    As Zea said, you're replacing the whole pump you should go with a smaller unit. However, if you just replace the motor you'll either need to match the SFHP (service factor x horse power) of the new motor with the old motor or you'll have to change the impeller to match the SFHP of the motor you get.
    Hi, I am new here.
    Problems:
    Jason
    Like the others have said it looks like you have a motor replacement. My question is; you stated that you just purchased this home, was there an American Home Shield policy or some other type of policy purchased that covers the appliances? Normally the pool equipment is covered too.
    I have a 1.5 HP "self-priming" pump and it looks like it is in good condition. Does it make sense to buy a whole new smaller pump to save on electricity? Does anybody have a pump brand and model they recommend?
    May 2009
    Youngsville NC
    395
    You need a new motor at the least. If you can find a 2 speed 1.5 HP motor, that would be your easiest replacement if you want 2 speeds (putting a replacement single speed 1.5 HP would be the cheapest motor to get). If you keep the same wet end and get the 1 HP 2 speed - you will need to replace the impeller as well, at least. At this point - it might make more sense to get a total replacement new 1 HP 2 speed pump if you really want that configuration.
    Another option would be to put a 2HP motor (2 speed) on your current wet end. Not the "most efficient", but at least it would work.
    So - your options -
    1. replace the 1.5 HP motor with a single speed 1.5 HP
    2. replace motor with 1.5 HP or 2 HP 2 speed motor
    3. replace whole pump with 1 HP 2 speed model.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    22,542
    If the wet end is in good shape, I'd just replace the motor with the same SFHP in a 2-speed model. You'll save enough in electricity costs to pay for the new motor.
    My main pump is now dead. I think I am going to replace it with a Intelliflo by Pentair. I don't want to use the booster pump i have because my vacuum was not doing anything. Can I hook up the Intelliflo and leave the booster pump where it is and not turn it on? I have a salt generator too. Photos are in my first post.
    Jul 2011
    Austin, Texas
    78
    Yes, I would leave the booster pump in place. Even if it is not used, it won't hurt anything to leave it there. You may decide to fix your Polaris and use the vacuum system again later.
    30K IG, Plaster with spillover spa, 9 ft deep end with spring base diving board
    48sqft DE Filter, 3HP VS motor, Hayward SPII, Raypak RP2100 Propane heater
    AutoPilot Pool Pilot Digital with SC-60 and pump relay (220v)
    Polaris 280. Pentiar Booster Pump, TF-100 Test Kit, Speed Stir
    Austin, Texas (It's hot)
    Jul 2011
    Austin, Texas
    78
    Can you post a picture of the left side of the salt water generator? I can't tell from the photos, what is the plumbing configuration on that end. I'm curious.
    Quote Originally Posted by Technigogo
    I updated the photo album: http://tylerreese.smugmug.com/Other/...264594_w7pSGpv
    Thanks for all your help!
