Results 1 to 19 of 19
Thread: Latest test results - do these numbers look ok?
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    FC - 1.5
    CC - .5
    TC - 2
    pH - 7.6
    T/A - 110
    CH - 200
    CYA - 70
    12'x36" / 2100 gal/ AG / Krystal Clear Model 603 filter cartridge pump ( cleans surprisingly well for a $35 pump!)
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Latest test results - do these numbers look ok?
    Quote Originally Posted by JulieLeo
    FC - 1.5
    CC - .5
    TC - 2
    pH - 7.6
    T/A - 110
    CH - 200
    CYA - 70
    FC too low. With 70 CYA, your FC range is between 5 and 10 and never below 5.
    You need to get some chlorine in there!
    Other #'s are fine.
    You're done SLAMing when:
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    I put my numbers into the pool calc. and it said add 11 oz of bleach.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Is your pool a Intex easy set pool? If it is, you are over estimating your pool volume. Intex has is at 1779 gallons. Using that volume I get 31 ounces of bleach, to go from 1.5 to 10 ppm FC with a 70 ppm CYA level.
    Butterfly's Avatar
    South Carolina
    10,045
    11 ozs of 6% bleach will raise your FC by about 2.5ppm.
    What #'s did you input for now and target?
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    My pool is an Summer Escapes 12'x36" and the manual said it is 2100 gal. volume.
    I put my the following numbers in the pool calc.:
    FC current - 1.5
    FC goal - 4
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Okay, glad you have the right volume. From poolcalculator I get 37 ounces of 6% bleach to go from 1.5 to 10 ppm (why would you want to go to 4). Let us know if you are having trouble with the calculator.
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    Quote Originally Posted by linen
    I don't think I understand how to read the Chlorine/CYA chart. Could someone give this dummy a quick lesson please?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You can just use the levels suggested in the poolcalculator (the values are fairly close to the chart). To use the chart, use the non-swg chart, go down to the row 70 for your CYA then across will show you 5,8,and 28.
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    How did you come up with bringing the FC up to 10ppm?
    Butterfly's Avatar
    South Carolina
    10,045
    The "Suggested FC Levels" will appear (in blue) near the bottom of the PoolCalculator.
    You must first enter your pool volume (gallons) and the current CYA (70) in the calculator.
    Try it and if you have problems, post back and ask questions. Someone will be around to help.
    In the interim, go add about 37ozs bleach to your pool!
    Butterfly's Avatar
    South Carolina
    10,045
    For 70 CYA, the normal FC range in the PoolCalculator is 5 to 10ppm.
    You do not have to go to 10, you could shoot for 8 and see how your FC holds.
    However, since you are below your minimum of 5, I also suggest you raise FC to 10 for now.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Absolutely raise it to the maximum for your CYA which is 10ppm. Falling below minimum can cause great havoc on your pool. And plan to make sure it's at 10ppm every night before you begin the next day. You're going to loose about half of your chlorine every day, and want to remain at or above your minimum of 5 at day's end. As such 10ppm is necessary for a full day of swimming and sun.
    If 10 ppm seems too high, you can do a partial drain to lower CYA to around 40ppm where you'll then need to make sure you raise it to 7ppm at night and never fall below 3ppm. Same ratio, but lower chlorine use/day. If you're in a very hot climate, 50ppm CYA might be appropriate for you.
    Adjust the calculator's now column for CYA, you will see different values change in the pink chlorine section at the bottom. The numbers that show there after you enter different CYA values tell you what to put into the target column for dosing calculations.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    Thanks for the great advise. Now I'm a bit worried because I'm going out of town for the weekend and I'm the only one who maintains the pool.
    Butterfly's Avatar
    South Carolina
    10,045
    I'd raise it to shock level, circulate for at least an hour, then shut it down.
    I don't think you'll have a problem. Have a good weekend.
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    When you say shut it down what do you mean?
    Jan 2010
    Central Valley, CA
    233
    I'd start monitoring the reaction of your numbers in relation to what the pool calc says it should. My pool manual said 9500 gallons and I'm actually closer to 7600. No fancy math, I just used the pool calc and played around until the pool was acting as the pool calc said it should.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    Oh also when I was doing the CYA test I probably should say that the number was more like 60 but I added more solution just to be sure I didn't see the black dot. Does that make sense?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I just wanted to clarify that Butterfly said to raise it to shock level (28ppm) and then shut it down for the weekend. Not 10ppm, that's your daily high level.
    "Shut it down", I took as meaning turn your pump off and let it sit over the weekend. AFTER letting the chlorine mix for an hour or so of course.
    The black dot should totally disappear. 70 is probably a better number to use for now. You don't want to undershoot your target levels and be away from the pool at the same time.
