Thread: Ozone and PH
    Jul 2011
    NE Oregon
    4
    Ozone and PH
    Does having an ozonator and circ pump, running continually, affect PH? I'm having a hard time bringing down my PH and TA; PH=8.0 TA=200. It seems like the constant aeration would keep the PH high. This is in a hot tub, 330 gals., 99 degrees. I added what the pool calculator suggested and it didn't have any noticeable effect; am I just being a chicken not wanting to dump copious quantities of muriatic acid in my tub?
    Grecian Swim Spa, 1900 gal, cartridge filters, Del Ozonator, 2hp-2 speed, 4 hp-Specht
    Tiger River Bengal, 330 gal, cartridge filter, ozonator
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Ozone and PH
    You're being a chicken
    The aeration from an ozonator, especially if on a lot of the time, does make the outgassing worse, but running jets is even worse. At any rate, a TA of 200 ppm would even have the pH rise significantly in a pool, let alone a spa. You really need to get that TA down A LOT and yes, adding a bunch of Muriatic Acid is the way to do it, but in a spa the process is much faster because you can aerate significantly with jets. Just follow the Lower Total Alkalinity process.
    Jul 2011
    NE Oregon
    4
    Re: Ozone and PH
    Thanks! I guess i missed that part of Pool School. I overcame my acidophobia ,followed the directions and TA is coming down. This is a great board!
