Results 1 to 8 of 8
Thread: Testing for salt in a chlorine pool
    Hey all ---
    I've been trying to learn as much as possible here before posting, but I still have a question.
    I have a chlorine pool... my general routine is get PH down with Acid, add chlorine with Chlor-Brite from Leslies. Also, we use the 3" pucks in a floater (I know, I know --- I'm learning to get away from all that stuff! )
    But I want to add Salt to my pool, to get that softer water feel... so I went to Lowes and got a salt test kit (strips) and a couple 40lb bags of Solar Salt.
    When I got home and tested the pool (before adding the salt), I was very surprised.... the strips show I have roughly 1,000ppm of salt already! I've been in the house for 1.5 yrs and have never added salt before, and I have a sand filter, so I do a lot of backwashing/refilling.
    The strips took a lot longer to finish their results then indicated in the directions... and I'm not sure how much to trust them. They say they test for salt as 'sodium chloride' which is salt, as far as I know.
    Any reason why I would have that much salt in the pool already? If I really do have 1,000ppm of salt in the pool, would it be bad to add a 40lb bag anyway? I have a 12,000 gallon pool.
    Thanks for the advice!
    25x12, inground (pebble tech)
    1hp pump, Pentair Triton sand filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Testing for salt in a chlorine pool
    Quote Originally Posted by JPBoston
    Better check your CYA level. I would stop using that stuff.
    Adding chlorine to your pool also slowly adds salt. You may very well be at 1000 ppm.
    It can take awhile, I have not timed mine, but I would guess 5 minutes. I would guess they are okay. Sodium chloride is salt.
    Most people who have salt but no swg use a concentration of around 2000 ppm. From poolcalculator.com, to go from 1000 ppm to 2000 ppm, you should add 100 lbs of salt.
    Jun 2010
    Glendale, CA
    513
    Chlorine IS salt! Seriously. The active form of chlorine is really just salt + some energy (that's how a Salt water generator turns salt into chlorine - it adds the energy). When chlorine does it's thing it expends the energy and becomes salt.
    At the bottom of the pool calculator there's the effects of adding chems section. If you look there you can get a sense of how much salt is in a Trichlor puck for instance in a pool your size.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Thanks for the quick advice guys!
    I added the (2) 40lb bags of salt that I already had and mixed it all in... I'll get some more salt soon.
    I know my CYA is probably thru the roof (I've been studying the effects of the chlorine pucks and CYA via this forum), it's been bugging me like crazy to find out. Just can't order a legit CYA test kit right now. I'll take some water to Leslie's and see what they have to report, even though we all know it probably won't be accurate.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    JPB,
    welcome to TFP
    The CYA kit at TFtestkits.net is only $17
    http://tftestkits.net/Cyanuric-Acid-Test-p48.html
    Better yet, even though the TF100 is a bit more, it WILL save you money in the long run by keeping you out of the pool store
    22,553
    Just as reinforcement I've never added salt to my pool and I have about 1600 ppm. I use the K-1766 salt test from Tftestkits so I trust that number. That, and the fact that it's been testing that for several months now.
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by lightingguy
    Chlorine IS salt! Seriously. The active form of chlorine is really just salt + some energy (that's how a Salt water generator turns salt into chlorine - it adds the energy). When chlorine does it's thing it expends the energy and becomes salt. .
    Well, technically chlorine is an element, and bleach (sodium hypochlorite) has sodium chloride (table salt) in it as a by product from creating sodium hypochlorite. So, you'll have sodium hypochlorite and sodium chloride in your bleach bottle.
    Thanks again guys... my wife was very skeptical of this endeavor -- after days of doubting me and rolling her eyes when I told her I could tell a difference... today she actually brought up that the pool water felt noticeably softer.
    This is significant because my wife is the type of woman who can't tell the difference of Blu-Ray vs DVDs, or 5.1 surround sound from a nice receiver and Polk speakers vs stereo from the TV speakers.
    As Charlie Sheen would say: "WINNING!"
