Results 1 to 10 of 10
Thread: Scale/Calcium is falling off the tiles
    iggy's Avatar
    Jan 2008
    The Cool Part of Arizona
    175
    Today I noticed a lot of white flakes at the bottomof my salt pool.
    FC =4
    CC = 0
    pH = 7.6
    TA = 90
    CYA = 80%
    Hardness 250
    This has been my normal for many months but last night we had a rain storm which raised the level above the normal level.
    I think the scale is coming off the tile around the waters edge of the pool.
    My questions is why did it start after the rain and would a too low ph make it seperate the scale/calcium from the tiles?
    In-Ground SWG pool 11,000 gal., Jandy CL460 Filter, 1.5hp Stealth Jandy pump, Paramount PV3 In-Floor cleaning sys., Goldline SWG, Hayward Color Logic 2.5 LED Light
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Scale/Calcium is falling off the tiles
    Normally calcium scale does not fall off that easy. Given you have a SWG, it could also be salt. Sometimes I get salt collecting on the tiles and then when the water level rises, it falls of and/or dissolves.
    Mark
    iggy's Avatar
    Jan 2008
    175
    Quote Originally Posted by mas985
    hummm that could be a possibility. I guess I need to taste it and see. LOL
    Why wouldn't it desolve into the water?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If it is Salt, it will dissolve in the water....
    Essential Links:
    Aug 2010
    Boston, MA
    176
    Though not necessarily immediately.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    iggy's Avatar
    Jan 2008
    175
    I'm 99% sure it is calcium deposts falling off the tile. It is thin flakes.
    All I can think is the water is doing it. Never seen this before.
    Has anyone seen this happen before?
    30,415
    What makes you think it is calcium scale? There is nothing in your test results to indicate a scaling condition in your pool.
    It could be one of many things that precipitated form your water onto the tile and is simply being released from the tile as the water rises.
    That is not a characteristic of calcium scale.
    iggy's Avatar
    Jan 2008
    175
    It could be one of many things that precipitated from your water onto the tile and is simply being released from the tile as the water rises.
    I do have a white ring around the pool on the tiles at water level. I was jsut thinking it might be relseased from the tile for some weird chemical reaction. It isn't salt but it is some large flakes that I can pickup and break in my hand easily. I know this sound weird but all I can think is it is from the scale buildup on the tiles.
    iggy's Avatar
    Jan 2008
    175
    Well I finally figured out where the white flakes were coming from.
    I increased the time the pool pump stays on as well as the SWG.
    The scale was coming off of the SWG cell and was entering the pool by the 2 closest return lines in the wall.
    So the heavy usage helped clean my SWG.
    All is well in paradise...
    mas985's Avatar
    Pleasanton, CA
    11,737
    When the SWG reverses polarity, it tends to sluff off the calcium build up which is a good thing. The bad part is that it goes back into the pool.
    Mark
