Thread: Vacation Chlorine levels
    Aug 2010
    UK
    27
    Hi Everyone
    My AGP has been up and running for 3 months now without a glitch (hurrah). But I'm off on vacation for 2 weeks tomorrow (aghhh!!).
    So I have a beautiful clear pool and I'd like to keep it that way.
    Over a 2 week period records show that I've used...
    2Kg of Dry Acid to keep the ph around 7.5
    250g of Chlorine with Stabilizer to keep around 2-3ppm
    (This includes 15 hours of swim time during this period)
    My plan
    Reduce the ph down to 7.2
    Get chlorine levels to 5
    Then get my elderly parents to carefully pour a pre-prepared 100g of chlorine into the pool in a weeks time.
    The pre-prepared chlorine would be mixed in a watering can ready to poor into the pool
    The pump will be on 3 hours per day on a timer.
    Note that I cover the AGP with a plastic sheeted polytunnel.
    Question
    Dow you think that would work ?
    Will the chlorine be OK sitting dissolved in water within the can for a little over a week.
    Intex Ultra Rectangular AGP 18*9*4
    Certikin hydroswim HPS .5hp pump
    Azur 15" Sand Filter (pentair)
    EGFM glass particles (10kg of 1-3mm and 25kg of .5 - 1mm)
    Calorex AW910 Heat Pump
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Vacation Chlorine levels
    What's the CYA level? It would seem that if you always use stabilized chlorine that CYA would be well above the level that 5ppm is appropriate for.
    Additionally, 5ppm of chlorine will be gone in less than two days. Regardless of CYA level. If your parents are able to pour stuff into the pool, why couldn't they pour bleach in? Are you able to purchase bleach locally? I realize you don't want to ask your parents to come by every day, but I fear that's your only choice even with your original plan because a week would leave your pool at 0 for about 5 days. 0 is not good... my pool went to 0 for maybe... 5 hours two days ago and everything went gaga, I had to shock it for the first time in two seasons (other than opening this year).
    Perhaps you could enlist a neighbor or a local teen (pay them?) to come and add chlorine? I do wonder if the pre-mixed chlorine solution would loose it's potency over time.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
