Results 1 to 7 of 7
Thread: Drying items right after testing?
    WestSidePool's Avatar
    Cincinnati, OH
    424
    I've been thinking about this for awhile, and after running my full tests yesterday I got to thinking.
    After you run your tests do you towel dry the test cylinders and the TC/pH test square off before you store them away in your test kit, or do you just store them away wet?
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Re: Drying items right after testing?
    I always put mine away dry.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    I dump out the test solutions, rinse the vials with the leftover sample water, then go rinse them again in the pool. Then they get set on the table to drip dry while I add whatever. So...sometimes they're dry and sometimes they're wet, just depends on what I have to add.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I rinse the test tube out with the pool water in my little bottle, shake, then store after I run each test. Then I rinse with pool water again before testing.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    I store my test cylinder upside down. Shake out excess moisture, but do not dry. Probably would be best if I did, though, just with our hard water and the buildup it causes. Just not convinient to dry. Rinse with new pool water before starting next test.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I do a D. I. rinse, put away dry. Years of habit for me.
    Essential Links:
    Cincinnati, OH
    424
    I've left them on the table when I'm adding stuff, but sometimes a gust of wind gets ahold of them. So I've just been rinsing and putting away damp, then re-rinsing before next use.
    I may start drying them out since my Chlorine drop test cylinder has been starting to black film up on me, so that needs a good cleaning.
    Eric
