Thread: some light green stains
    i've noticed some light green stains lately in a couple of places, including seat in deep end, bottom portion of alum ladder and a bit on the shallow end steps. left a trichlor tablet on the seat for a min or so - no effect. however, these stains wipe away w/a simple swipe of a finger. i'm diligent about water chemistry (thanks to all of you), but i sometimes find it difficult to keep up w/all the leaves which fall from trees near the pool. i could also be more diligent about brushing.
    FC: 3
    CC: 0
    PH: 7.8 (already added some MA)
    TA: 70-80
    CYA: 30-35
    CH: 260
    water is crystal clear, no problems w/OCLT.
    are these light stains anything to worry about?
    20k gal, cartridge, IG, plaster
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Re: some light green stains
    Your FC is on the low side go up to at least 5 or 6 ppm.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,983
    If they just wipe off, they're not stains... It's either algae or something like pollen. Run your chlorine at the high end and see if they don't go away. If they do, it was algae.
    pollen has been unusually high this year, so that could certainly be the culprit. raised chlorine, then brushed. hopefully light green areas will not return. appreciate the replies, thank you.
