Thread: Adding Maintenance Chlorine daily
    Hi! I have learned a lot from this board and am hoping to care for my pool properly with your help.
    I have a question about the minimum chlorine level and the target level. I am passing the overnight chlorine test, the pool is clear and in balance. I add liquid bleach to bring it to 8ppm at night (cya/fc chart)
    But I have some daily loss due to sun that reduces it down to 5-4 ppm by evening time (Oklahoma full sun).
    Do I just adjust every night to bring it back to 8ppm over the night, or should I add even more chlorine so that by the end of the next day of sun it is still at 8ppm?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Adding Maintenance Chlorine daily
    It all depends on the CYA level. If the target is 8 and the minimum is 5, and you're dropping to 4 before you replenish, then you need to bump it up a little higher.
    The key is to never let the FC drop below minimum.
    Great. And, I also have a spa waterfall into the pool that I usually let circulate to cool the water overnight. Does that contribute to chlorine loss? and if so, what should I do about it?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Bumping your CYA level up might also help. It shouldn't raise the amount of chlorine you have to add every day, your target (high) and minimum will just jump to the next number up and it should reduce the loss a ppm or two.
    To answer your question though, yes. Every day you add chlorine to reach your target (high) in preparation for the next day's use/chlorine loss.
    If you perform an overnight test you'll know if the waterfall is contributing to the loss but I doubt it (no sunlight plus no algae/CC = little or no chlorine loss). Do one night without the waterfall running, and the next with. Compare.
    The waterfall may contribute to PH rise however, so if that is ever an issue look to the waterfall when troubleshooting.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    30,421
    Two things and ONLY two things consume chlorine. Sunlight and organics in your pool. The waterfall is irrelevant to your chlorine loss.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Yup.
    To OP....A full set of test results would really help us help you ...especially your CYA level If you are passing the OFCLT and you are losing more than 3ppm per day, your CYA is likely too low, but before you go adjust it, please let us know what your current CYA level is and how you measured it
