Thread: Black Algae Shocking
    First let me say throughout all of this my pool water has looked perfect. Perfectly clear sparkling water. That said, I have a little black Algae in my pool. I had a little a couple of years ago and cleared it up. My SWG went out recently and the BA made a come back. It is like the pool has the measles in a couple of spots on the walls and some on the bottom of the pool. Since I stumbled on you guys I have kept the FC higher than the pool store had me keeping it.
    To start working on the BA, about maybe 2 weeks ago, I first went around the pool and everything I could reach with a TriChlor tab I rub all the spots pretty good. Those spots haven't come back yet. At Dark 7/31 I put the SWG on boost and it raised the FC to about 10 and I kept brushing at it. I noticed some of the spots sere starting to get hollow looking, more like a circle, than a dot. I then noticed a few of them would some time have a little dark line coming out of them, it almost looked like a piece of pine needle laying on top of them but there isn't a pine tree in sight and that is not what it is. If I passed the vacuum over them, it would take it right off. have any of you ever seen anything like that? The brush would take of off too but I figured it would be better to vacuum it out. I was thinking either the stuff is starting to die, or it's trying to spread.
    So I went to shocking last night, 8/2/2011, after dark, I lowered the PH to 7.2 brushed the pool good and started adding bleach.
    Before I started all this my test results were:
    7/31
    FC 5
    CC 0
    TC 5
    TA 80
    CH 280
    CYA 65
    Borates 50
    PH 7.8
    8/1 FC to 10
    8/2 Started Shocking PM
    PH 7.2
    FC 26.5
    CC 0
    Here is the part that surprised me, 6:30 AM
    FC 26.5
    CC 0
    It passed the OCLT. I kept at it anyway
    I tested several times and added bleach during the day today to keep the FC up in the brutal sun and heat today.
    Tonight I brought it up to
    FC 35
    CC 0
    I'll see how it tests in the morning.
    My questions for some of you smart guys that have dealt with BA before is, does a small amount of BA not consume the FC like other algae does? If it was already dead, why doesn't it brush off the pool plaster?
    If not how do I know when to stop shocking?
    Will spots I can't reach in the pool ever come off? I really don't get how something can rub off so easy with my finger, or a Tri-chlor tab not come off when I scrub on it with a foot wide SS Brush?
    Should I put a Black Algaecide in the pool?
    All Ideas are welcome guys
    TIA
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
    22,548
    Re: Black Algae Shocking
    They make a tablet holder that you can attach to your pole. You could take it (or make one) and hold a tablet on the spots where you can't reach. I think a good going over with the tablets would be better than anything else you can do.
    Thanks Bama Rambler, could you point me where I could find one of these tablet holders by any chance?
    1 1/2 HP Challenger
    Located in NOLA
    Butterfly's Avatar
    South Carolina
    10,045
    You can google for more info, but I did find this first:
    http://www.lincolnaquatics.com/2011Catalog/2011_67.pdf
    You might want to just try to make one.
    Scrub with wire brush before and after the trichlor scrub.
    You're done SLAMing when:
