Thread: Would someone run numbers for me please? Lowering TA
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Does anyone have ten minutes to use their Pool Calculator for me today? My laptop is being weird, and I cannot get the Pool Calculator to work for me. DH is unreachable, and if I go clearing caches and fiddling with my computer, he will be upset with me.
    I wish to lower my TA. Here are my numbers. How much MA 31.45% do I need to add that will lower my TA, but not send my pH lower than 7.2 in the first dosing?
    23,600 gallon pool
    FC is 5.4
    CC < .2
    pH is 7.6
    TA is 120
    CH is 320
    CYA is 20 (intentionally this low, for the Chemtrol)
    Borates at 50
    Salt is 3330
    Pool temperature is 84 degrees
    Thank you very much for your help. I want to get going on this somewhat lengthy process.
    (If I enter my figures into Pool Calculator on this machine, the laptop/calculator tells me I have only 23 gallons in my pool and that I'm going to raise the TA by thousands! Yikes! )
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Would someone run numbers for me please? Lowering TA
    I get 55 ozs, about 7 cups 31.45% MA to lower pH from 7.6 to 7.2.
    You're done SLAMing when:
    22,553
    I get 81 oz. Since you have 50 ppm borates it takes more than normal.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Hey you two! Thank you so very much for helping me out--I very much appreciate it!
    Happy Swimming ~~
    Lana
    Butterfly's Avatar
    South Carolina
    10,045
    oops, I failed to enter the borates in PoolCalculator
