Thread: Electrical Questions
    I cant find a definitive answer in my local codes.
    How far from the pool does the control panel for the pump timer/SWG need to be.
    Being that the cord on the cell is only 15' I am very limited.
    Also, does it need to be above water level?
    Thanks!
    24' x 52" Round AG Pool, Hayward Aqua-trol SWCG, Hayward Pro Series High Rate Sand Filter, Hayward Power Flow LX Pump 1HP 60GPM, Hayward H100ID Heater.
    South Central NJ
    3,192
    Re: Electrical Questions
    The power supply for the cell should be near the equipment pad, no more than 12 feet from where the cell is going to be located. Where you get power for the controller/transformer is up to you. Some cells have an available extension to go beyond the 15'.
    Scott
    Owner of - PoolGuyNJ LLC
    I want to relocate that box above the water level. To the rail next to the steps in the second photo. My concern, is that far enough away from the pool wall?
    I tried my hand at photoshopping the idea. the post in this picture is 7' from pool wall.
    Will that meet code?
    22,553
    NEC 680.22 says it shall not be less than 6 ft from the inside of the wall, if it meets the following:
    (1) Consist of single receptacles.
    (2) Employ a Locking configuration.
    (3) Are of the grounding type.
    (4) Have GFCI protection.
    If it doesn't meet all those things it can't be less than 10' from inside the wall.
    Thanks bama!
    I believe it fits the criteria.
    It's going to be close to the 6' mark though
