Thread: Solar Cover and Algae
    Hi all,
    We haven't put our clear solar cover on our pool for a couple of weeks, and so it has been sitting folded -- sometimes wet -- in hot sun during that time. I've fought algae in the pool a couple of times this year, and now that I have it cleared up, I'm hesitant to put the cover on for fear the cover itself might harbor algae. Am thinking about using a push broom to brush the cover with a bleach/water solution. What do you think? What ratio would you use? Any other ideas?
    Thanks.
    28k gallon in-ground vinyl. Sand filter. Hayward pump. Manual chlorination.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Solar Cover and Algae
    That sounds like a good idea. If you see algae on the cover, use 2 parts water to 1 part bleach and scrub the areas well and allow to dry before putting it back in the pool. If the push broom is too rough on your cover, try a thick napped paint roller to apply the bleach solution.
    Love TFP? Become a
    TFP Supporter!
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Just and FYI. If you leave your solar cover sitting out in the sun, make sure it's covered with something reflective, or unfolded, so the sun doesn't heat it up. The heat when folded or rolled up can cause early failure of the cover.
    I learned my lesson this year, from leaving it out at the end of last year. When we used it this year, it started deteriorating in the pool. Dots everywhere. Had to keep emptying the skimmer baskets or they would clog.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    Thanks zea3 and thanks for the tip westside -- much appreciated.
    Do you think 2:1 water:bleach is a little heavy or just right?
    Thanks.
