Results 1 to 11 of 11
Thread: PH issue
    PH issue
    Long story short. No power to fuel message. K-1 was burned out. Got board replaced after 2 weeks of dealing with warranty issue. Tried to keep bleach in the pool to keep algae at bay. Fast forward 3 weeks... PH showed high so I put in MA as usual. Do this once a week every week and don't have issues. But recently I have put in almost a gallon and PH wont move off extremely red. It has me wondering if I went so far the other way that it is super low PH and past the orangy yellow into a deep red?
    24,000 gal SWG pool
    Bunch of stuff
    Aqua Blue Pebblesheen
    2 Colorlogic LED lights
    Huge Hayward D.E. filter
    more stuff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,607
    Re: PH issue
    Even if you poured the gallon in all at once..........it would lower your PH by 1.28 for 24k gallons. It must be dang high.
    Re: PH issue
    Quote Originally Posted by woodyp
    and I don't know how it would have gotten so high. I did shock it last week over 3 days with 1000+ oz of bleach bringing FC up to 28 but that was a week ago. I understand you get false highs during the shock but FC is back to 5
    24,000 gal SWG pool
    Bunch of stuff
    more stuff
    Jul 2010
    England, UK
    156
    Re: PH issue
    At very low pH, the indicator is yellow, so there shouldn't be any confusion with high pH, which is red/pink.
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    Re: PH issue
    Lost confidence in my testing, was getting very faint chlorine read on the quick test. Had super chlorinate on 2 hrs, SWG on 95% with pump running 8 hrs and was getting very faint reading. Took it to pool store last week and they read 22ppm chlorine and said it was so high it was "bleaching out" the test results.
    Turned chlorinator off to bring it back down over the weekend and still getting no reading on my taylor test. Took it back to the store and they got the following
    FC 6.2
    TC 6.2
    CC 0
    PH 7.6
    Hardness 320
    Alkalinity 56 (with correction) low
    CYA 62
    Why am I getting no color from my chlorine test? I even added shock granules, (3 or 4) and a LOT of color showed up. I tested my spa and got typical reading... I really am starting to think their test is off and I have 0 chlorine..
    I tried the drop test and when I added the powder it had a slight tint of pink but not much and didn't change tint as I added the drops of solution.
    24,000 gal SWG pool
    Bunch of stuff
    more stuff
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: PH issue
    Try the powder again. Add more powder this time, enough to turn it hot pink.
    And, if you do actually have 22ppm chlorine you'll be dropping in 44 drops. Don't stop till it changes to clear, even if it's 44 drops or more.
    High chlorine requires more powder. If the first scoop doesn't turn it hot pink, add more.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: PH issue
    I suggest you use the OTO (yellow drops) test. This is a bullet proof test for the presence of chlorine.
    If you don't get some yellow, you have no chlorine!
    You're done SLAMing when:
    Re: PH issue
    Quote Originally Posted by Butterfly
    Is that the small bottle with the yellow lid that you drop five drops into the plastic vial with the color codes along side it? If so, then zip chlorine.
    24,000 gal SWG pool
    Bunch of stuff
    more stuff
    30,421
    Re: PH issue
    Yes it is. (it's called an OTO chlorine test) That is the correct way to find out if there is chlorine in your pool. The test is simple, fast and inexpensive.
    Okay, so you have zero chlorine in your pool. DO NOT ask your SWG to bring your FC back up to normal. You need to do that with CLorox even though your SWG may be working fine.
    Could you submit a current complete set of test results (no need to do the chlorine) that you perform with your own (not the pool store's) testing? Tell us what your water looks like.
    Re: PH issue
    I'm an idiot.
    When my PH and Chlorine drop bottles ran out a few weeks ago I ran in a pool store and bought what I thought were better replacements. Red and Yellow lids on the bottles.. well it was a Taylor Reagent #3 Apparently that is NOT what is needed for the 5 drop test. I bought the OTO today and bam!! chlorine... ah feel so dumb....(Steve Martin voice)
    24,000 gal SWG pool
    Bunch of stuff
    more stuff
    Butterfly's Avatar
    South Carolina
    10,045
    Re: PH issue
    Quote Originally Posted by Starsky
    I'm an idiot.
    aw, you're not the first one to do something like that!
    I remember one time when I.... nevermind .
    Good news is that you got chlorine! Let us know how it goes.
