Results 1 to 14 of 14
Thread: Poolskim review.
    Poolskim review.
    Hi All,
    I've been looking at this device for years and hesitated buying it.
    I have a black locust tree near my pool which is absolutely beautiful BUT it is the messiest **** thing ever. Little tiny brown leaves everywhere. It just so happens the one area of my pool is kind of a dead zone. Leaves just collect on the surface and sit there. After a while they get waterlogged and fall to the bottom. Tired of the maintenance I figured I'll drop the $100 and see if this thing works. It arrived quickly and took about 15 minutes to install.
    I LOVE this thing! It has amazing suction and collects everything that was in the dead area. A true godsend and well worth the $100. I just wish I would have thought of it
    This is one of those products that just plain works. Its not too obtrusive either and easily removable if necessary. My Blue Diamond gets along with it too.
    Joe
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Jul 2007
    Northern NJ
    299
    Re: Poolskim review.
    I have loads of maple trees that drop leaves, helicopters and other nasties. The poolskim is the BEST thing that has happened to me! I, too, love mine and am glad I found it. You're right, it is the BEST $100 I have spent for my pool!
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    Oct 2010
    Houston, TX
    151
    +1 on the Poolskim. Fantastic device.
    I have 2 skimmers which didn't work too well with a low flow pump. On grass cut days, tons of grass clippings would be floating on the surface of the pool, and many would sink to the bottom and litter the bottom of the pool. Not to mention the leaves, flowers, seeds, etc. from multiple trees surrounding the pool. Now with the Poolskim, the surface of the pool is practically debris free, and therefore the floor of the pool is much much cleaner as well. All the stuff is in the Poolskim!
    15k gunite pool. Intelliflo VF. Autopilot SWG.
    2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
    Just to add to this, I recently got a Poolskim and am equally pleased with it. It has vastly cut down on the amount of time I have to spend manually skimming. The Poolskim works much, MUCH better than the actual skimmer on my pool. Once the pump has been running for a while, the surface is pretty much totally clean even in my somewhat odd "S-shaped" pool, which has corners that don't get much circulation.
    I did find that the unit needs a decent level of inlet flow in order to function up to its full potential, and that the better you can get overall circulation working, the faster it will work. In my case this meant limiting the flow from my other three inlets, and controlling their direction at the same time.
    I found that rather than using the little "inlet limiters" that come with the unit, I had much more success by swapping out my eyeball jets for the "slotted" type. These have slots along the side of the ball rather than a hole in the middle, which has two effects on the flow. First, they reduce the flow quite a bit, and you can adjust the amount by turning the ball so that more or less of the slot is exposed. This of course directs more flow to the Poolskim inlet. Second, the slotted jets can redirect the flow a full 90 degrees so that it's directly along wall rather than out into the pool. This is MUCH more effective for creating a rotational circulation in the pool, and it induces stronger flow right along the wall where debris will sometimes hang out. This in turn causes surface debris to make it's sway to the Poolskim (or the pool's skimmer) much more quickly.
    I tried the eyeball jets with smaller holes at first, but even when turned as far sideways as possible, these still directed the flow away from the wall, which didn't induce enough circulation where I needed it. The slotted eyeball jets made a dramatic improvement in this regard, and pretty much solved this problem.
    I highly recommend the Poolskim, as well as the slotted eyeball jets.
    Larry
    Los Angeles, CA -- 22K gallon in-ground plaster pool with spa, built around 1980, replastered around 2009-2010.
    Pentair Intelliflo VS (variable speed) pump and Quad 100 DE filter. Older "MiniMax" gas heater. Pentair Rebel cleaner.
    NO SWG - Liquid Cl only. Taylor K-2006 test kit.
    Oct 2010
    Houston, TX
    151
    Quote Originally Posted by lalittle
    Larry
    Can you possibly post a pic of this slotted eye ball, or where to get one? I haven't seen them at the pool stores, and I am getting some debris stuck on the walls like you said despite a completely clear pool surface with the pool skim.
    Jun 2011
    Cape Girardeau, Mo
    125
    Beezar they look like this and here is one place they are available...http://www.amazon.com/Hayward-Direction ... B0038A8LEQ
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    Quote Originally Posted by beezar
    It looks like fsteve65 beat me to it. The picture he posted is what I'm referring to, except that I got the Pentair version, which does not have the little symbol on the flat part (it's just flat and smooth in that spot.) The reason I opted for the Pentair is because it is offered in dark gray instead of the light grey that Hayward offers. The dark grey is a much better match for my plaster since the light grey ends up looking quite light underwater. My plaster is not very dark, so I originally bought a light grey version thinking it would match, but to my surprise it did not, and I ended up swapping it for a dark grey version.
    Some other information that may or may not be useful (which I came across when searching for these) is that the Hayward version appears to be called a "Hydrosweep," as opposed to their normal eyeballs which they call "Hydrostream. The Pentair version is on page 248 of their 2011 catalog (https://www.pentairpartners.com/prod...log2011_US.pdf), under the "Wall Fittings - Inlets" section. The Pentair part numbers for the slotted eyeballs are:
    White - 540000
    Black - 540001
    Dark Grey - 540002
    There also appears to be a number of knockoff versions of these. I'm not entirely clear what (if any) differences there are from one brand to another other than slight cosmetic changes.
    Note that the white ones were the easiest to find, both online and at the more robust local pool stores. The grey and dark grey versions, however, took some hunting.
    Larry
    Oct 2010
    Houston, TX
    151
    Quote Originally Posted by fsteve65
    So I got the slotted returns and yes, they work great. My pool and the walls of the pool are even cleaner then before!
    Still loving the Pool Skim. I tell every pool owner I know to get one even if they don't have many trees/flowers around their pool, because there's just a lot less junk that sinks to the bottom of the pool, and a lot less debris that enters the skimming baskets, meaning less work spent emptying the baskets and possibly less frequent backwashes.
    Of course you need to empty the poolskim, but that's a snap.
    It's great to hear that the slotted returns worked for you. When I first found them and discovered how well they worked, it really surpised me that they weren't more well known.
    The overall system that can be created with the slotted jets and the Poolskim really does work remarkably well, and like you, I highly recommend it to people.
    Larry
    Dec 2011
    Charleston, SC
    100
    Hi all, Just ordered my Pool Skim and was curious...i have an older pool with slanted 1" diam return pipes....can I use the
    Polaris 1" stub pipe connection recommended by PoolSkim or do I need to have a pipe that return straight on perpendicular to the wall? Also, is it just as easy to find a pvc adapter that can transition a straght 1" pipe to a 1.5" threaded connection? Thanks in advance for any comments or advice!
    IG Gunnite Pool Size: 25K gallons (20 x 40, 3'6" to 6" depth) with 2 huge Baker Hydro cartridge filters under the skimmer baskets on the suction side, 2 mech timers
    BRAND NEW PLASTER! Quartzscapes/Diamondbrite, Newer Polaris 280, Brand New Hayward Maxflo VS, Brand New Pentair Intelichlor
    I will conquer the black algae this pool season!!!
    May 2013
    Arizona
    112
    Very interested in pools skim sounds like something would work for me
    However bringse to my issue before I found you guys I had a guy he installedy pentaire pump and dollar filter since it worked great never paiduch attention. Till now when I'm comfortable to start making some upgrades. Low and behold he installed my intake and out take backwards. My intake should be way below waterline with a gray cover with holes in it to avoid things like leaves and my out should be near top where eyeball should go. It's backwards he plumbed it wrong. Now I know y always frustrated that water level had to be so high to run pump without getting that sucking noise. How can I fix this reason I had someone else Inatall I'm handicap hands unsteady and my husband is a computer cut. I want very much to make following kids this year:
    1. Install my thru wall skimmer hawyard (not large mouth) which I purchased last yr and still not installed
    2. Run my auto vac once the skimmers installed I've been told can. Of run my auto vac without the skimmer
    3. Water fall PVC to cool my water gets up to 90 degrees here when our temps start staying at 110 live in az.
    Help on what to do about the reversed plumbing should I fix that before adding amy mods if so how?
    As always thank u for your help
    Jun 2014
    Youngstown, OH
    163
    So I just bought one of your pool skims... The fittings included don't fit my return and I'm not sure what I need. Lowes was useless. I got some grumpy old man who didn't want to help me.
    It looks like my existing ring on my return is 2" but like I said he was unable to help.
    Went to the pool store but they were closed. Any idea what I need?
    Thanks
    24' Round x 54" Bliss XL Above Ground Pool 14,090 gallons // Hayward S270T Pro Series 27-Inch 350lb Sand Filter // Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed // Hayward H200FDN Natural Guess Heater // K-2006 Test Kit
    Youngstown, OH 44514
    Jun 2014
    Youngstown, OH
    163
    I got it.. I was trying to screw on the OUTTER threads of my return, not the inner.. Inner fit..
    Hooked it up.. However, stuff is floating right past it!! Any help?
    http://youtu.be/8ECxL_pCwjc
    Thanks
    Aug 2014
    Shallotte, NC
    693
    SWAG:
    From what I saw in the video.... the skimmer needs to be lower in the water and it appears that, instead of a vacuum being created, the water is trying to bubble OUT of the skimmer... so that would be pushing things away from the skimmer.
    Never having seen this thing, but having a rough idea how it must work.... I'd say (1) lower the skimmer or raise the water level and (2) make sure that whatever creates the suction (guessing a venturi) is aligned perfectly with the water coming out of the return (nozzle).
