Results 1 to 7 of 7
Thread: CLOUDY WATER! CANNOT KEEP CHLORINE, CYA IS A MYSTERY???
    Please help
    First of all results are:
    FC 1.5
    CC barely .5
    TC 2.0
    TA 110
    CH 80
    PH 7.8
    CYA under 20, water does get cloudy, but I can still see a greyish dot! - I was clueless when first got pool and did my TF-100 first test and had not added CYA, so I kept saying, the d$@n dot is still there!!! Then, I think Butterfly asked me if I had ever added it? DUH me! I hadn't! Anyway, now I have added it, 3/4 of the total it said to, bc I saw if you get to much it's more of a pain to drain and add water to get it out. I started adding it 3 days ago, by a sock in my skimmer basket, I remember somewhere said that it could take up to a week to read. I have vaccuumed to waste once, bc the pool looks so cloudy and I always have high swimmer load. BUT, I am burning off bleach like nobodys business STILL!!! I just put in a big 6% 182oz jug at 10am.
    Just cant keep bleach in! I know its hot, but, I've still gone through about 5 big jugs in the past three days. Pool still seems cloudier than when I finally got through shocking it all went downhill
    I need
    SW, Virginia
    16,400 Gallons AGP
    27'x52" Esther Williams
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    Sep 2009
    Greentown, IN
    914
    Re: CLOUDY WATER! CANNOT KEEP CHLORINE, CYA IS A MYSTERY???
    Have you done and overnight FC loss test?
    If you lose more than 1FC overnight you need to go through the shock process.
    If you have more the .5 CC you need to shock
    With a high swimmer load, the heat, and your cya not showing on the test yet.. it may just be that the chlorine is being used up that fast... esp. if you have other problems like cloudy water/algae.
    If you allow your FC dip below what the range levels are for the cya you added are you are asking for trouble right now since it's been so hot out. FC at 1.5 is not high enough.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Yes I did , I passed...for one night
    So, do I need to shock AGAIN ?
    My husband may divorce me if I keep spending this much money on bleach. My daughters 4th Bday Party is Sun and I really need this pool looking good!!! So, if I have to...I have to
    Do you tink thats what I should really do? Shock again?
    Thanks so much!!!
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    30,432
    Snyder5.
    Since your pool is cloudy and consuming chlorine (and your chlorine is too low), there is little doubt you need to shock your pool.
    1. How much CYA did you put in the pool?
    2. How much ppm did you calculate that would give you?
    3. When did you shock the pool?
    4. Did you shock the pool according to the exact instructions in Pool School?
    5. Have you put anything else in the pool other than Clorox over the last few weeks?
    Started shocking immediatley, gonna be a long night
    Added 70-75oz of stabilzer, the granule looking one, by sock - calculator sad 88oz, so to make sure I didn't do too much I underdid it a little.
    88oz, said it would give me 40 CYA, so, I thought I could get at least 30
    Started shocking last Mon 7/25, and finally 7/31 overnight I only lost 1ppm of FC, pool looked clear and I followed all shocking in pool school. I did have a hard time bc I always have ALOT of swimmers! I took a week to look good, and alot of bleach and alot of scrubbing!!!
    No, only added bleach to pool, actually it's been prob month-month and half since I even put in Soda or Borax, so, just bleach for a long time. I dont even walk into pool stores, haha, then on 7/31 started adding CYA (should have done it sooner), cya went in fast from sock in skimmer!
    But, now this
    Anyway, I'm shocking...again! And, here I thought the high swimload use to help keep the water stirred up, now, I think its hurting my cloudy pool
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    Butterfly's Avatar
    South Carolina
    10,045
    What shock level are you using?
    24 hours after adding the CYA, consider it in there and adjust FC/shock levels accordingly.
    You should not be swimming while shocking. Also, along with brushing, make sure to check all nooks and crannies for possible algae hiding places
    You're done SLAMing when:
    I was shocking to 20 ppm, on the higher level for my pool, but knew it was hot and had no CYA.
    And, oh man! I thought I could let them swim an hour after adding bleach, , they weren't in it much, but I know it wasnt helping from the test readings
    I really have to get in to brush or vac real well, is that ok? The pool wall is so high, I just cannot reach with any pressure?
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
