- Aug 2, 2011
- 2
Hi all, I am a new member from UK.
My chlorine level and ph level is correct but since I have got the pool 2 years ago I get small particles laying at the bottom if the pool is not used for 2-3 days.I have used flock to try to get them all to the middle which did not work.
The only way I have found to remove them is to use a large garden hose , run it out to the front of my house and painstakingly move the end of the hose all over the bottom of the pool and suck the bottom level of water out along with the small particles.
No way will my pump remove this stuff, I have tried everything including covering the filter cartridge with very very fine fabric.
Any help will be appreciated
Thanks
Simon
Thanks
Simon
