Thread: Advice on purchase parameters
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Hey:
    Wondering if any one could answer or lead me to a good link to help me if I purchase a SWG. What features are important? Which are unimportant? And what should I avoid?
    PS. Still can't figure out how they plug in, I have a single locking style receptacle on a post 6' from my above ground pool. No other source of power.
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    franke's Avatar
    May 2011
    Forest, VA
    32
    Re: Advice on purchase parameters
    You would want it to come on when your pump is running. Should be powered in parallel with your pump.
    25000 gal Rectangle IG, Vinyl, SWCG -CircuPool SI45 Plus, Sand Filter, 3/4 hp Pentair pump with US motors echotech EZ variable speed motor
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Quote Originally Posted by franke
    My setup is a GFCI circuit breaker then the timer/switch, still in the house, to a dedicated single lock type receptacle on a pole 6' from the AG pool. Do I need to run a new circuit? Or, install a duel receptacle? Which I question if that's to code???
    10,800 gallons
    TF-100 Test Kit
    22,544
    Most plugin style swcg's come with either the twistlock plug or the straight blade plug. You order the one you need. On those units, they have a receptacle that the pump plugs into, and it'll match the plug.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Oh, that make's a lot of sense. Sorta piggy backed.
    10,800 gallons
    TF-100 Test Kit
