Results 1 to 11 of 11
Thread: Chlorinator not keeping up.
    Jandy chlorinator with a salt water pool. Three years old with little to no problems.
    Anyone have the codes for problems?
    Code 60 was put out yesterday. With 100 - 105 degree temps it may be just the weather pushing the system to the limits.
    Cleaned the SWG in April and it was caked up with scaling.
    Thanks for the help. Any information appreciated.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: Chlorinator not keeping up.
    Hi, welcome to TFP! Do you know the model number for your unit?
    Love TFP? Become a
    TFP Supporter!
    I will write it down and reply.
    Jandy 1400. I get a code 60 when I start up the pool manually.
    2 speed pump. Cartridge filter.
    22,551
    Code 50 or 60 shows up when it starts. It's showing that it's detected the power source. It's either 50 or 60 depending on whether you have 50 or 60 Hz power.
    Have you checked the cell for scaling lately?
    Can you post a full set of test results?
    A lot of times the unit not keeping up when it was in the past, is because of some water issue.
    Here's a link to the Troubleshooting Guide for that unit.
    I just got an orange service light. I think it needs to be cleaned. I am going to clean it tonight and check it again. I usually have to clean it at the start of the season and the later part of the season. Water temp is 94 - HOT Record heat in Texas!!
    Cleaned it. It was full of white calcium deposits. I purchased a liquid test kit with drops instaead of the test strips. Should be able to keep the water ph so this SWG does not get caked up as often.
    Sep 2009
    Greentown, IN
    914
    Make sure your salt levels are correct for that model.. I know.. obvious, but sometimes that's what'll get you stumped.
    You might double check your cya as well. Mine was low this summer and I thought my swg wasn't working... turned out I just had my cya too low so the chlorine kept getting used up too fast.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    My cyanic acid has had to be added twice because I have had to add so much water to the pool this DRY summer.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    CYA doesn't evaporate out from my understanding. Could your CYA level be too high?
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    bobodaclown is right - CYA doesn't leave by evaporation. If it is high, you will require a much higher chlorine level.
    Perhaps you could post a full set of test numbers?
