Results 1 to 8 of 8
Thread: morning startup trips heat pump circuit breaker
    Hello
    My pool is 3 years old and I just had to replace my Hayward pump 1.5 hp. Several times a week when the timer starts the pool in the morning the heater will not come on, the circuit breaker trips. Could this be somehow related as to why the pump went bad? I was hoping the new pump would correct this but it didn't
    The pump is on a separate 220 amp circuit and the heater on it's own 440 circuit. I had the heat pump company come out 2 years ago and it was working as it should.
    I'm thinking a delay of some type is that possible?
    Thanks
    Tom
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: morning startup trips heat pump circuit breaker
    Is it the heater or pump circuit breaker that trips? Does the timer try to turn them both on at the same time or is there a delay to allow the flow to start before the heater powers on?
    It is the heater that trips and yes they come on together by the timer
    Tom
    Is the heat pump 440 volts? What is the amp rating of the circuit breaker for the heat pump?
    Support the site
    I will get that info and get back to you. Not positive on the 440 but I think so
    Tom
    This is what I have
    Looks like 80 amps for heater and 40 for pump??
    Tom
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    To me it looks like you pump is 20 amp, 240 V and you heater is 40 amp, 240 V. What amperage service do you have running to the pool subpanel? You may want to switch out your 40 amp breaker, with a new one to see if it is a breaker problem.
    I have 80 amps going to panel. I'll switch out the breaker
    thanks
    Tom
