Thread: Hayward H400IDL2 Gas Heater won't Ignite
    Aug 2011
    Manteca Ca.
    8
    I have a Hayward H400IDL2 natural gas heater that is approximately 5 years old that will not ignite. When I tried to start it for the first time this season it wouldn't start at all it kept on blowing fuses. I figured out the transformer was bad replaced the transformer and the fuses, tried to start it up and the blower was bad, changed the blower and it still didnt fire. Had a service guy come out he replaced the vacuum pressure switch and it still didnt fire and he gave up! so I trouble shot it again and wound up bypassing the vent pressure switch (I know it isnt safe but i was getting irritated ), Tried to start it and it worked, but only for about 4 hrs. Then I cleaned the burner tubes and replaced the ignitor, and it wouldnt fire at all, I dont think it is getting gas now! That is where I stand with this wonderful heater! Is it possible the gas valve is no good? In the manual it is says to check the valve for a short, so I checked the terminals on the front of the valve and it isnt shorted. Does anyone have any insight on this problem, any kind of advice, ideas are greatly appreciated!!
    Thank you in advance!
    Mitty1964
    15'X48" cheapo Intex metal frame pool. 4400 gallons.
    Cartridge filter
    The only thing I could find about the pump is it says 1000 gallon filter pump.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Hayward H400IDL2 Gas Heater won't Ignite
    Welcome to TFP, by the way. Sorry I can't help you.
    Aug 2011
    Manteca Ca.
    8
    Thanks for the welcome, at least you replied!
    Cartridge filter
