Results 1 to 7 of 7
Thread: Pool coping, is it supposed to be pitched away from pool?
    Currently replacing my pool coping and redoing my patio around my pool. The patio will be pitched away from the pool, but the mason feels it's ok to keep the coping (bluestone) level with the pool?
    From what I understood the coping should be pitched away from the pool as well. Is this accurate or is the patio the only area that needs to be pitched away from the pool?
    Thanks in advance for any info you can provide.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Re: Pool coping, is it supposed to be pitched away from pool
    Maybe it depends on the material of the coping??? I'd thnk stone you'd want level but that's just what I think.. Whether it's right or not is another story. It's probably left up to personal preference too.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Mine is pitched away, and I can't think of any pool I've ever been in where it's not.
    You don't want anything running into the pool. Imagine this: patio is somewhat dirty. Someone climbs out of the pool, dripping. Patio now has thin mud on it. And it's running into the pool....
    tgmb's Avatar
    Jul 2011
    san jose, ca.
    92
    I'm with Richard. Away is the the way to go.
    20k gal. 36' In ground Med. Blue plaster, two-speed EcoPump EP6, Pentair 3.14 sq. Ft. Sand w/zeosand, Spectralight SL 500, RayPak 2100 heater, Polaris 360,GE Timer 15087, Borates 80 ppm.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    I've got travertine and if it's sloped away from the pool, it is sloped EVER SO SLIGHTLY. Now the deck on the other hand is visually obvious that it's sloped away from the pool. When I get out, water does remain on the travertine, but in this weather, it doesn't exist for longer than 1 minute before it's gone. He can certainly keep it a bubble out on the level and you'll never notice that "EVER SO SLIGHTLY"
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Thanks..we went the ever so slightly route. Cant even notice it.
    Dec 2010
    560
    That's so funny. I just looked at the dates. I just thought it was a new thread. Oh well, at least it is something that can be searched for the next guy/gal... LOL
    TFT-100 test kit
