Thread: Advice - Vendor to order Hayward TriStar Replacement motor
    PVille's Avatar
    May 2009
    Purcellville,VA
    39
    I have a Hayward TriStart 1.5 HP FRHP (SP3215Z1BER/T63CXDCZ-1653) pump that is making anoise and blowing the breakers. I disconnected it from the pump assy. and it still blows breaker after running 10 seconds with no load.
    I'm looking for a recommendation on reputable company to order a replacement pump from. I called my pool store and they said we have one in stock. When my wife picked it up it was a generic AO Smith motor made in China. I opened the box and it looks "similar" to the Hayward pump but does not look like it would be an exact fit. Maybe I'm being crazy but I think I would prefer to have the original part to replace the old one.
    Recommendations? Should I use the AO Smith generic and be done with it?
    In ground 15 X 33 10,400 gal. Fiberglass
    Two Returns, Two main drains, One skimmer
    Aqua Logic SWG, Hayward TriStar 1.5HP
    Hayward C3025 (325 sq /ft) Cartirdge Filter
    Solar Heater (Details at http://www.bakerlabs.com/solar)
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Advice - Vendor to order Hayward TriStar Replacement mot
    Most Hayward's come with AOSmith (a.k.a Century) so it probably is a direct replacement. Here are the replacement motors that AOSmith has on their web site.
    Mark
