Results 1 to 12 of 12
Thread: New Intelliflo - Poor flow/circulation
    I am having a terrible time trying to get my new Intelliflo pump to circulate the water.
    The symptoms are:
    Pump basket only about half full.
    Bubbles in pool during priming.
    I must open the valve directing water to the spa to get any circulation there. But doing so loses the circulation in the pool.
    Cannot get the Hayward Navigator vacuum to operate.
    These symptoms change. A day or two after I think I got it figured it reverts back to poor operation.
    I have cleaned the filter several times and the flow is a little better for a few days.
    My pool is small, about 10,000 gal. with a raised built in spa.
    I have not been able to use the pool since installing this pump.
    24,000 gal, in-ground, vinyl, hayward de filter, automatic chlorinator with tricolor tabs
    22,548
    Re: New Intelliflo - Poor flow/circulation
    You have a suction side leak somewhere.
    Check the skimmer weir to make sure it's moving freely and correctly.
    Check the pump strainer basket and clean and lube the seal.
    Check the basket drain drain plug(s). Clean and lube them and make sure they have the o-rings on the if they use them.
    I checked all of the above. Replaced plug o-rings. Cleaned and lubed basket cover. Skimmer weir moves freely. The only other thing I can think of is the threaded pipe inlet. It does not appear to have a leak but is there a way to check it before I re plumb it?
    Thanks
    30,419
    Sometimes, you can successfully immerse the suspected area by pouring water over it slowly, pump running. That would stop the air coming in and identify the source.
    Dec 2010
    San Diego, CA
    1,137
    Is your water level low? Are you seeing a vortex in the skimmer?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Water level is good. I will try running water over the pump inlet.
    Thanks
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Got a picture? Check all connections with water. nice constant flow, not a jet stream, but enough to create a seal.
    Tried the water on all connections on the suction side. I could not tell if it helped or not.
    I took it apart and re-plumbed the suction side. At first it looked like it helped. The basket filled to the top. The flow started out better but did not last long. Today the basket is only half full again. Flow is poor.
    What am I missing? I am getting very frustrated and am having thoughts of making it a vegi garden.
    Apr 2011
    Murrieta, CA
    2,360
    Silly question but you double checked the intake valves are fully opened?
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    What happens to the water level in the pump basket when you switch the suction to draw from the spa? If the pump basket fills, the problem is on the pool side. If the level stays the same, the problem has to be at or after the diverter valve on the suction side.
    If its on the pool side, maybe the line from the skimmer is partially clogged?
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
    I re-did the plumbing from the pool/spa divert valve to the pump. I think there was an air leak at the intake threads. At first that did not seem to help so I cleaned the **** out of the filter. Now I have good flow to both the pool and spa and good suction at the skimmer. My Hayward vac. even works. It has only been 2-days so I hope it lasts.
    Now that it is flowing do you think my speeds or ok for a 10,000 gal pool with spa:
    2-hours at 2000 to get stronger flow to spa and extra skimmer suction followed by 10-hours at 1600 rpm
