Results 1 to 7 of 7
Thread: Backwashing
    Jul 2011
    Webster,Wi
    59
    Backwashing
    We have been getting alot of rain lately and the water level is pretty high, can I backwash the water down some or should I just use the waste setting on my valve? Can you backwash the filter too much?
    18'x52" Intex round AGP, 2650 Krystal Clear SWG pump with sand filter and a Hayward H100ID pool heater. TF100 test kit to keep the water sparkly clean.
    Sep 2009
    Greentown, IN
    914
    Re: Backwashing
    You can use your backwash for this and it shouldn't hurt anything. You could also run the backwash as long as you need and then run a long rinse cycle.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jul 2011
    Webster,Wi
    59
    Re: Backwashing
    If it ever quits I'll Drain some out and check my readings and go from there. Thanks
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Re: Backwashing
    It's the perfect time for super cleaning the filter by backwashing it a long time to lower the water! It won't hurt it one bit. It's being put to use that way instead of just pumping it out on waste.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,565
    Re: Backwashing
    Only thing I've been backwashing around here is my water meter puttin' water......... IN.......... the pool.
    Sep 2009
    Greentown, IN
    914
    Re: Backwashing
    woodyp... we're getting ready to add some water right now but I hate too... enjoying the warmer temps right now and don't want to cool down the pool. I'm sure where you're at you enjoy adding a cool bit of water to yours
    I could also stand to backwash a bit but that would only add to the low water problem.
    MK1985... could you send a little of that rain my way? We are getting desperate for some... and not for the pool, but for the garden and the farmers fields. Hubby says there are cracks in the yard that would swallow a matchbox car right now!
    Test kits compared
    Purchase test kits
    Jul 2011
    Webster,Wi
    59
    Re: Backwashing
    6" of rain since Saturday and still getting some today, if I could I'd send you some. Haven't done a complete test now for about a week only the ph and chlorine qiuck test. What am I going to notice or look for when I do a complete test, I have been running the pump like I always do.
