Results 1 to 9 of 9
Thread: At a loss
    Jun 2011
    Longview, TX
    11
    At a loss
    I have had my pool up and filled for about 3 1/2 weeks now. I cannot seem to get any chlorine going. Basically Im adding about 400 ozs of bleach a day. SUre right after that I can do a simple Test from the Taylor test kit (I also bought the TF 100) and the chlorine reading is actually orange instead of yellow because I just poured bleach in it..but by the afternoon the next day..nothing. I can never get the chlorine present in order to do any of the other tests such as FC drop test. I have done those but nothing..but of course, when the Taylor test is clear then I didnt really expect much. If I go more than two days without adding bleach the bottom starts to get slippery..so I throw a few hundred (or more) oz's ob bleach in it..the slipperyness goes away...but the Taylor shows nothing...so long story short..if you were to average the last 3 1/2 weeks out..IM putting two big jugs of bleach in my pool a day and never get a chlorine reading except immediately after I put it in. My PH is really high and have put in the Muriatic Acid and maybe lowered a shade for a day. Im at a loss..at this rate im spending about 210 a month on bleach. THanks.
    Doughboy 24ft AG
    1.5 HP pump, Sand Filter
    15,000 gallons
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Re: At a loss
    If you have the TF-100, pour your bleach in and let it circulate for a bit and then do the drop test. I think you need to know what is eating your chlorine and the drop test will show if you have CCs present. If that turns out to be the case, you will need to do a proper shocking procedure... getting the bleach in there to achieve shock level and keeping it at that level for a prolonged period of time.
    Can you please post a full set of results to include FC, CC, TC, pH, and CYA?
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: At a loss
    Quote Originally Posted by dattia
    Since you are also struggling with high ph, please include the TA reading (dattia probably meant that instead of TC).
    Jun 2011
    Longview, TX
    11
    Re: At a loss
    Hey guys..thanks for your replies. .I have done all of those tests and get nothing..several times. I felt like I was just wasting my test kit chemicals as one test (cant remember which one) says keep dropping the chemical until it turns pink or something..and it never did..20 drops later nothing..so I just stopped..I also did the one where you add the chem until you can longer see the dot...nothing..saw it fine until the tube was full..but I will do them again and post results. Thanks for your help. Your right though... something is eating it as soon as I put it in. Will do as soon as I get home from work at about 530 central. thanks again.
    jj
    Doughboy 24ft AG
    15,000 gallons
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: At a loss
    Quote Originally Posted by jj5000
    Sounds like the FAS-DPD for FC test. You either had no FC at the time of testing, or your FC was very high. Were you putting a scoop of the DPD powder before you started adding drops?
    sounds like you have no CYA, and that would explain why your chlorine goes away so quickly. Please read: http://www.troublefreepool.com/pool-...ary_pool_guide and reread all of pool school soon.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: At a loss
    The ph test should work. Plus, if 20 drops hasn't turned the alkalinity and calcium hardness tests the required color, keep going. It means you haven't finished the test yet. Alkalinity or CH at 200+ is not uncommon.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: At a loss
    I agree with Frogabog, my tap water is around 300 for both TA & CH. Keep adding drops. Once I knew it was that high I started adding 5 drops at a time till I knew I was close.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: At a loss
    It sounds like you are on the verge of an algae bloom. Go ahead and add enough CYA to raise it to 30 ppm as per The Pool Calculator and complete the shock process as if the 30 ppm of CYA was registering on the test. It will take around a week for the CYA to register once it has all dissolved. Keep the pool at shock level as often as possible until you pass the overnight test.
    Love TFP? Become a
    TFP Supporter!
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: At a loss
    Hey JJ,
    The pink test you refer to I think maybe something got mixed up when you did it. Try doing exactly as the instructions say one more time, make sure that when you drop the powder into the 10ml sample it turns pink. (you can do 25ml, but only if you need very precise measurments, the 10ml sample is good enough for this purpose).
    Then you will use the R-0871 one drop at a time till the pink solution turns clear. Count the number of drops, and multiply by 2. Each drop equals .5ppm.
    Then use the R-0003 reagent on this same solution (should be clear). Drop 5 drops of that into the sample, swirl. If it turns pink you have combined chlorine. (I think this might be where you got stopped up, 5 drops only of the 3rd reagent DPD reagent R-0003)
    This last step is only needed if the 5 drops of R-0003 turn the sample pink. Go back to the R-0871 reagent, add that one drop at a time until the solution again turns clear. Count these drops, they are again worth .5ppm each. This number, plus your first number equals your total chlorine (TC). The difference between free chlorine (1st result, FC) and total chlorine (TC) is the combined chlorine (CC) value.
    Let us know how it goes. Make sure to get a PH, That will be 5 drops of phenol red from the blue box if you're using a TF100. The PH is a red topped bottle in the Taylor K-2006 kit (I forget the number, it says phenol red).
