Results 1 to 14 of 14
Thread: 21 ft pool...help me choose a pump sand filter combo.
    Jul 2011
    Lehigh Valley, PA
    163
    21 foot pool. Is 1hp 2 speed pump enough on half speed to just run and use the 1hp for cleaning ?
    Was looking at this heyward pump SP15922S (1HP 2 speed) or this SP15932S(1.5 HP 2 speed).
    to combine with one of thesethe S180T(18 inch) or the S210T (21 inch)
    If anyone can help Id appreciate it.
    21' All Steel AGP with Resin caps, Heyward S244T Sand Filter, Heyward 1HP 2 speed pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: 21 ft pool...help me choose a pump sand filter combo.
    I have that size of pool and that exact pump (1 hp 2 speed that is). Works great for me, I generally only run it on high when running my roof mounted solar panels or when I am running my vacuum (which I do not do often). Besides that, I run on the slower speed 24/7. The 1.5 hp is oversized in my opinion, so not a good idea for you pool.My filter is a 20 inch meteor which I think is rated for 45 gpm (I will have to look). For filter, definitely go with the 21 inch (at least over the 18 inch). Pentair makes a 3/4 hp 2 speed pump that I almost bought, and would have been a good fit for this size pool.
    22,553
    a 1hp 2-speed is fine for your pool. You'll only have to run it on low except when vacuuming or backwashing. I'd opt for the largest filter I could afford.
    Jul 2011
    Lehigh Valley, PA
    163
    Great thanks guys. Does it matter if I only have a 1hp pump and say a 24" sand filter ? Will it be powerful enough ?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    More than enough power
    22,553
    Just echoing what Dman said. The 1 hp pump and a 24" filter is a good match.
    Jul 2011
    Lehigh Valley, PA
    163
    Thanks so much for the answers. I was looking at this filter...24" --there seems to be some wildy varied prices from 24" filter to filter...will this one get the job done ? Is there something cheaper that willl be equally effective ?
    http://www.poolsupplyworld.com/poolsupp ... /S244T.htm
    Id like to order from amazon if possible(I have prime) because they ship REALLY fast.
    22,553
    The S244T is a great filter. Any of them in the 24-26" range that holds about 250#'s of sand will do.
    Jul 2011
    Lehigh Valley, PA
    163
    thanks I will order that on then from pool supply world. They are cheaper than amazon.
    I have the Wilbar Oyster Bay 21 AGP--steel with res caps. I did not get a skimmer with it...are all wide mouth skimmers the same size ?
    I was looking at this one...
    http://www.amazon.com/Hydro-Tools-8939G ... 361&sr=8-2
    Pelican pools wanted 150.00 for a skimmer. Sounded like a rip so I passed
    22,553
    That one is fine.
    Jul 2011
    Lehigh Valley, PA
    163
    That one is fine.
    Any idea if the S244T comes with a base ? or for theat matter...do I NEED a base ?
    22,553
    It comes with a base. It doesn't come with the pump/filter combo base unless you order the combo.
    Jul 2011
    Lehigh Valley, PA
    163
    ok thanks. I saw some reviews online that said it didnt come with the base.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I have the S220T (22" 250lb) on a 24ft pool if you are looking to save a few bucks, is more than adequate for a 21' pool. As far as a base is concerned for my filter and pump, I just used a 36x36" PVC ac condenser pad found at your local hvac/plumbing supply store
