Results 1 to 18 of 18
Thread: still shocking
    Jul 2011
    Terre Haute indiana
    60
    still shocking
    been keeping pool at shock levels since july 23. its still dropping about 6ppm by oclt. cya of 40 been shocking at 18. ph 7.6 TA of 130 and a ch of 260 water looks great. just wonding if this is normal to take this long or am i missing something. gone through a lot of 12.5 1gal. chlorine
    19500 gal, IG, haywood s-200 sand filter & pump, 3/4 horse single speed motor, vinyl liner, tf 100 test kit, installed early 80's, Terre haute,In
    22,551
    Re: still shocking
    What day did you get the test kit?
    If I read your other thread correctly you really only been shocking for about a week or less and in the beginning you weren't keeping it at shock all the time. That tends to slow it down some. It's pretty typical for it to take a week or two to complete the shock process.
    Keep it up, you'll get there.
    Jul 2011
    Terre Haute indiana
    60
    Re: still shocking
    sorry for the delay the internet been down. got the test kit a week ago monday. get the numbers up to 18 to 20 in the evening and next am its down to 11 to12 been like that for a little morre than a week, will they gradually go up or jump up to just losing 1 or none at all. thanks for your help. pool looks great
    30,426
    Re: still shocking
    Hard to say but most folks report a pretty dramatic decrease in chlorine consumption. You have been doing the right thing by adding in the evening and I suspect, in the next day or two, you will see the change in your test results.....I bet it will be fairly sudden.
    Jul 2011
    Stockton, CA
    63
    Re: still shocking
    I'm pretty new to this forum, and have just gone through a similar situation. From my limited experience, I found that going to higher shock levels, and shocking several times a day finally brought the problem to a close. I now have clear water, bleaching to FC 7-8 each evening, OCLT of 0-1, CC 0-1, and evening FC of 3-4. In sunny California, I lose about 40% of the FC each day.
    Keep shocking; it works.
    22,500 gal, in-ground, plaster, Intelliflo VS 3050 pump, Sta-Rite 400 sq. ft. cartridge filter, solar panels on roof
    May 2011
    Clearwater, FL.
    446
    Re: still shocking
    Hi REBARBEE ,
    Mine was doing the same when I shocked my pool, I read here that I should try going 3 above my shock value of 16 (CYA of 40) so I went up to 19-20 and then I wouldn't ever fall below my shock value of 16 with my free chlorine loss.
    It didn't take very long for that to work and clear the water 3 months ago, has been perfect ever since with very little work to keep it this way!
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Apr 2011
    Lynchburg VA
    393
    Re: still shocking
    Same here, I shocked for over 3 weeks until I started bumping my shock numbers up a little bit....after that it was only 2-3 days. The harder you hit it and the better you are about maintaining the shock ppm the quicker it seems to go.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    May 2011
    New Jersey
    37
    Re: still shocking
    I'm new to TFP as well. But, I just followed the "shock process" advice and it took 8 full days to stop losing FC overnight. The last two days I actually kept the shock level at about 40 because my CYA is 70-80. (I have an SWG). I think that' s what finally did it. Good luck. I'm sure you'll be ok soon.
    Kristyn
    8100 Gal 12X20 vinyl IG pool. Hayward H200 heater, super pump and Pro Grid DE3620 Filter.TF100 test kit
    Jul 2011
    Terre Haute indiana
    60
    Re: still shocking
    ta is 150, ph 7.6, cya 40, cc of .5 or less, keeping fc up around 20-22 pool looks great, no visable signs of anything growing and still losing 5 to 7 from around 8 pm to 6 am. still using 12.5 chlorine. just keep shocking?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: still shocking
    Yep, keep shocking. Make sure to check & brush all possible hiding places, like ladders & light niches and don't forget to brush, brush, brush!
    You're done SLAMing when:
    May 2011
    New Jersey
    37
    Re: still shocking
    We had great looking water but there turned out to be a patch of algae in the light niche. We dove in to search and my hubby found it. Never would have seen it otherwise. Used a toothbrush to scrub it. Brought the shock level up extra high and in two days we passed the oclt. The pool has been holding since monday night. Keep at it. You'll get there.
    Kristyn
    Re: still shocking
    You should be checking fc levels at least every couple of hours not just at night and morning. I have a feeling your fc is dropping below shock level during tye day giving algea a chance to survive. Adding chloine several time a day to maintain shock level is the fastest way to fix your pool
    24' 52" Above Ground
    BBB
    LOVE TFP
    TF Test kits, Pool School, Pool Calculator
    Jul 2011
    Terre Haute indiana
    60
    Re: still shocking
    Made It. had a oclt loss of .5 and a cc of less than .5 think i will leave it at shock levels for the day to be sure, going to start checking ph and ta a little closer now. thanks everyone
    Butterfly's Avatar
    South Carolina
    10,045
    Re: still shocking
    Quote Originally Posted by REBARBEE
    Sounds great! The water is clear, too, right?
    Got a pic for us?
    Jul 2011
    Terre Haute indiana
    60
    Re: still shocking
    sorry no pics but yes the water is very clear, never looked this good. am i understanding this right that when the chlorine levels drop to my target of 7 with a min. of 3 that the swings wont be as big. i think one post said to expect a 50 percent loss.so if i'm at 7 in the eary am it should drop to 5 during the day and then bring it back up to 7 that night. hope you can figure out what i'm trying to say.
    30,426
    Re: still shocking
    I understand and you are correct. The chlorine loss you're predicting (2ppm daily) may be closer to 3 but you're close.
    Jul 2011
    Terre Haute indiana
    60
    Re: still shocking
    its looking good. have a fc of 10 falling to goal of 7-3, cc 0, tc 10, cya of 40, ch 280, ph 7.5 and ta of 150. pool school recommended ph level for vinyl is 70-90+ . is 150 to high and do i add the acid the cal. says at once? think it was around 45 oz
    Aug 2010
    Boston, MA
    176
    Re: still shocking
    You don't want to add enough acid to drop TA=150 all at once, because your pH will go way too low. To lower TA, you drop the pH to 7.2, aerate to raise the pH back to 7.8 (reducing TA in the process), and repeat as needed. There's an article in Pool School with fuller details.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
