Thread: Algae in my pool
    Algae in my pool
    I have owned my pool for about 10 yrs. we used chlorine free chemicals like pristine blue. I recently switched to the bbb method and love it but after about a week of 95 degree weather and high humidity I noticed little green flakes floatingf in the pool. I have shocked with chlorine bit they keep coming back. Is this alge and what am I not doing enough of or doing wrong.my ph and ta levels are where they should be at. its a 20 x 12 above ground doughboy.
    I am still learning the bbb method so any help would be greatly appriciated.
    thx Lana
    Sep 2009
    Greentown, IN
    914
    Re: Algae in my pool
    Never heard of algae flakes...
    Do you use a pool cover/solar cover. If you do and it's an older one, it might be losing some pieces and sometimes they tend to float.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Sep 2009
    Greentown, IN
    914
    What are your pool tests coming out like... give us the full battery...
    FC
    CC
    TC
    ph
    TA
    Ch
    Cya
    Salt
    Test kits compared
    Purchase test kits
    Quote Originally Posted by Suziqzer
    yes I use a solar cover, but I purchased it only a year ago, I took a look at it and it doesnt seem to be falling apart or look worn.
    FC
    CC
    TC
    ph
    TA
    Ch
    Cya
    Salt
    I dont have a test kit for all the tests but here is what I have,
    TH 250
    TC 1
    FC 0
    PH 7.8
    TA 40
    PPM 0
    Sep 2009
    Greentown, IN
    914
    After only a year the cover should be fine. Was just my first thought.
    Looks like you definately will need to go through the shock process since you're FC has managed to get to zero, plus the problems you've noted. First you'll want to get your ph down a bit to around 7.2 and you have to find out what your cya level is so you know how high you will need to get your FC to kill whatever you have going on in your pool.
    I recommend your read "how to shock" in the pool school section of the forum. Also.. get yourself a good test kit... You'll be glad you did! Best investment you can make!
    Test kits compared
    Purchase test kits
