Thread: Water temperature when testing
    New pool owner here. My test kit instructions say the pool water should be at room temperature when tested. During the summer my pool water stays around 90 degrees F. How important is it that the water be room temperature for accurate testing? Should I take my samples inside and let them cool to room temp before testing, or is it not worth the trouble?
    Assuming that testing 90 degree water will throw the tests off, does anyone know how much and in which direction? Would it be possible to adjust the results to compensate?
    15'X48" cheapo Intex metal frame pool. 4400 gallons.
    Cartridge filter
    The only thing I could find about the pump is it says 1000 gallon filter pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Water temperature when testing
    Cold water slows down the reactions with the various reagents.
    Don't worry, just pull a sample and test.
    Great. Thanks!
    Cartridge filter
