Results 1 to 10 of 10
Thread: Slightly cloudy water
    Hello everyone! This forum is such a great resource to new pool owners like us
    We have a 27ft round above ground pool - installed in June. We've been following the pool store's instructions for chemicals as follows:
    Wednesday - check Ph - adjust to 7.4 - 7.8 as needed (have checked and never needed to adjust)
    Wednesday - check total alkalinity -adjust to 80-120 ppm as needed (never needed so far)
    Add 4 quick tabsto skimmer at night
    Sunday: check Ph adjust as needed same as above
    Add 1 1/2 lb shock and swim directly to pool water
    Add 4 quick tabs to skimmer at night
    Add 4 oz natural kleener
    Add 9 oz poly 30 algaecide
    Add 1 lb anchor (only recently started doing this since they had originally crossed it off list but sold me stuff anyway so I asked what I should do with it
    A few weeks ago, when it was REALLY hot here, the pool looked a little cloudy - not discolored, just not as crystal clear as it had been. Pool store said to double up on quick tabs when it gets really hot. Did that and it cleared up.
    Husband and at pool store to pick up patch kit and talked to guy there about cloudiness again and he says if weather is really hot again, use bag of shock instead of shock and swim to keep pool clear. Tried that, seemed to work, went back to regular routine since temps dropped.
    Over 90 again for last couple of day, added extra quick tabs last night, pool is a bit cloudy this morning....
    We run the filter all of the time. We also have an aqua pro heat pump that we run off and on to get the tmp of pool where we like it. Ran it yesterday for a bit but there doesn't seem to be a correlation between running it and cloudy pool.
    If you're still with me, any advice re: cloudiness? Also, I am wondering about the whole routine we are on - it's expensive which I would not mind as much if the pool was always staying crystal clear!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Slightly cloudy water
    Welcome to TFP!
    You are being pool-stored. Your cloudiness is likely a result of inadequate chlorination along with high CYA.
    You should check out Pool School , particularly
    Basic Pool Care Schedule
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    If you can post a set of test results it'd go a long way in helping us diagnose whats going on.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Textbook description of Pool Stored.
    I concur with John T.
    I suggest you head over to Pool School and get educated. If you really want to get a sparkling pool (that will be the envy of all who see it) in a hurry, go to http://tftestkits.net first and order up a TF100 and a speedstir. Then go to Pool School.
    I spend a couple minutes a day on my pool, and it is so clear you can look through the deep end, about 8 feet, and tell that the drain cover screws are Phillips head. And I just use liquid bleach and Muriatic Acid. And a proper test kit! No fancy additives. No clarifiers, no algaecides. Never need to add "shock".
    Once you become a BBB'r, you will never want to go back. Prettiest, sparkalicious water you will ever see. Looks like a sea of glass!
    18x52 Ultra Frame with 1600 gph sand filter and intex skimmer
    thepiratemorgan's Avatar
    Aug 2010
    Central NY
    185
    Quote Originally Posted by Richard320
    LOL !!! Totally agreed.
    And again I say ... I swear I could read a 14 font letter off the bottom of my 52" deep Above Ground ... ok maybe 16 font because I'm getting old, not because the pool is any less clear!!!
    You NEED a test kit like the TF-100, it WILL save you money, time, frustration, and possible illness in the long run!!
    14,600g / 24ft. Round Above Ground with Solar Cover
    18" Hayward Pro Sand Filter
    1 HP Hayward Powerflo Matrix Pump running 10am - 8pm
    Full Sun (when we get sun ... LOL): Approx. 10am to 7pm
    Using the Trouble Free Method, and loving it!! Arrrrrrrr!!!!
    Sep 2009
    Greentown, IN
    914
    If you go by what the others have said ....read the pool school section and get yourself a good test kit. You'll be pleasantly surprised at how easy it is to have a sparklingly clear pool all summer regardless of the temperatures.
    The people here know what they are talking about and it's awesome. I encourage you to read through the forums as well and ask any questions you have as you go along.
    Welcome to TFP!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Welcome!
    ^^^^^^^^^^^^^^ What they said ^^^^^^^^^^^^^^^
    Have your pool people ever asked you to check chlorine? Your prescribed routine and testing lacks the most important information. What is your chlorine level? Second most important information needed is CYA level. Actually, they are both equally important. For the time being, and so we can help you, can you take a sample to a pool store for a complete set of test results?
    The test kit recommended above is essential. If you wish to cease pouring $$ into the pool via the pool store, the information provided here will do that for you, and it's FREE. Read pool school, more than twice. And ask any question here. Plenty of peeps around to more than happy to help.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    May 2011
    Clearwater, FL.
    446
    What more can I add?
    All is true with above posts, as I went through the same thing with my pool store all of last summer my first year with a pool, just as you are describing.
    One day last May I decided I wanted to know more than the pool store was telling me to do. I Google'd "pool chemistry" and lead me to this TFP forum.
    I started reading a lot and realized that I needed to do something different, so I went down this road of TFP way.
    I have never been more satisfied with the results I MYSELF have achieved!
    My pool is perfect ALL the time, is very easy to take care of and all my family want to come and swim at MY house now!
    My pool care total was $8.41 for the month of July except electric and a pool net! (unbelievable here in FL)
    # 1
    Get a TF-100 kit, this is the best tool I have ever bought for my tool box! It can fix ANY pool water problem I have with my pool.
    It tells me where I am with my water at all times. I wanted to learn as much as I could in a very short period, so I ordered the XL option with my TF-100 so I could test a lot more to help me understand this madness!
    Once you have ordered your kit, just keep reading here and learn from what we did. Post your test #'s here as soon as you get your kit and we WILL be around to help you get POOL SPARKLYITIS status!
    This is what you will get if you do this the TFP way...
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Nov 2012
    Puerto Vallarta, Mexico
    124
    I look at the white PVC drain cover in contrast to the dark tiles in my pool for cloudiness... Generally, i have crystal clear water... If it becomes slightly cloudy, i'll whip out a good FAS DPD test kit recommended by the good people here, to first see if i have CC's. If i dont, then i attribute the cloudiness to high pH, too high a CH or TA too high. Usually its due to the pH creeping a little too high, if it does i just add MA and the cloudiness goes away quite fast!
    I always examine the pool surfaces if anything (algae) is trying to get a foothold.
    Usually, if the pH gets a little too high, the water gets slightly but not too noticeably, cloudy but goes away with some MA
