Results 1 to 14 of 14
Thread: New Pool Collinsville Texas
    Jun 2011
    North Texas
    8
    We closed on the pool note, build will start on Friday 8/5.
    22 X 38 Free Form Gunite
    650' pool area
    110' perimeter
    3.5' to 9.5'
    Diving board
    SR Smith Turbo Twister Slide
    6 ton Moss Boulder waterfall
    Aqua Blue Pebble Sheen
    Also 18' X 20' Cedar Cabana for Pool Table
    I will include many pictures as the build progresses.
    Approx 30,000 I/G Gunite, Pebble Sheen Aqua Blue, All Pentair equip. DE 60,
    Intelliflo 4x160. Free form logoon. Stenner pump and 15 gal. barrel for liq. chlorine. Oklahoma Flag coping, moss rock boulders.
    tgmb's Avatar
    Jul 2011
    san jose, ca.
    92
    Re: New Pool Collinsville Texas
    If I may suggest something missing-you need some shade, over the water and the sitting area. We use ShadeSails. Get spmeting, or you will roast in in the sun. (Even in the water.)
    I sank 15' posts 5 feet in ground, using
    500 lbs concrete for the anchor. Don't bake in the Texas sun-shade all the pool and sitting areas.
    20k gal. 36' In ground Med. Blue plaster, two-speed EcoPump EP6, Pentair 3.14 sq. Ft. Sand w/zeosand, Spectralight SL 500, RayPak 2100 heater, Polaris 360,GE Timer 15087, Borates 80 ppm.
    tgmb's Avatar
    Jul 2011
    san jose, ca.
    92
    Something.
    tgmb's Avatar
    Jul 2011
    san jose, ca.
    92
    When we first moved in the house, we would roast in the California sun, which is not nearly as bad as the sun in Texas. (We moved from Louisiana.) The sails made ALL the difference. I highly recommend incorporating them into your design- that, or something similar. (Don't mind the landscaping- we're redoing everything right now...)
    Tom
    Jun 2011
    North Texas
    8
    Shade
    Hi Tom,
    Thanks for the advise on the shade.
    We have planned on several shade structures.
    An attached pergola will be added to the cabana as well as many market umbrellas through out the area.
    I will look into some shade sails.
    Chris
    JulieLeo's Avatar
    May 2011
    Atlanta, GA
    90
    Nice plans!
    12'x36" / 2100 gal/ AG / Krystal Clear Model 603 filter cartridge pump ( cleans surprisingly well for a $35 pump!)
    tgmb's Avatar
    Jul 2011
    san jose, ca.
    92
    I am partial to the sails, obviously, just make sure you use poles that are properly mounted and anchored, with a minimum 1/4" wall. (I used 1/8th inch wall, and my poles bend under load. ) use wire rope cables, turnbuckles, and heavy duty caribiner style clips- you can generate huge wind loads with these things- you ddon't want to cut corners.
    By the way, your plans look great..
    Jun 2011
    North Texas
    8
    Well they dug the hole last Thursday. Plumbing and metal came today.
    Here are some pictures.
    Jun 2011
    North Texas
    8
    More picture.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Looks great! I wish I had a deep end in my pool
    Somewhat cheaper than a shade sail (but not quite as effective or convenient) is to have a bunch of umbrella sleeves put in when they pour the deck. Then, you can move standard umbrellas around to wherever you want them. We have a 13' offset umbrella for which I built a heavy base with locking casters. It hangs out over the pool nicely, but was not cheap.
    Jun 2011
    North Texas
    8
    Well here it is Wednesday and the pool is gunited. Now it really starts to look like a pool. It will have to cure for a week. In this Texas heat, it will be tough to wet it down enough to slow that down.
    More pics.
    Aug 2010
    MA
    173
    That's one of the finer gunite jobs I've seen. Looking good!
    Doesn't appear to be 9.5 ft deep, though?
    Completed: June 2011
    18' X 38' IG Vinyl, 3' - 8' depth ~ 24K gallons
    2 skimmers, 2 wall suctions, 3 returns, 1.5" piping
    Hayward Equipment: 1HP Tri-star 2-speed, Aqua-Plus SWG,
    Star-Clear Plus 175 sqft cartridge filter, Colorlogic 4.0 LED
    The Pool Cleaner 4X(suction)
    2011 Jacuzzi J-280 Hot tub
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Unless that guy spraying the gunnite is 5' or less, it's close to 9.5 feet. It never looks as deep as it is.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Jun 2011
    North Texas
    8
    I measured all the dimensions after they were through.
    It is 9.5 in the deep end and 3.5 shallow. It is a foot wider than my contract states. But I'm liking that.
