Thread: Crystal wave / Aquaria vinyl inground pattern: anyone have?
    Can you provide any pictures if you have this liner? Crystal wave / aquaria. Stressing out over the final decision, which is due tomorrow AM. Thanks!!
    Allison
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Crystal wave / Aquaria vinyl inground pattern: anyone h
    you got lucky
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    X-PertPool's Avatar
    Exeter, PA
    1,385
    BTW, in regards to picking out a liner usually whatever your first gut reaction is to is the one you usually end up with.
    water always has a blueish tint to it, and there are some liners that are brown. The water color knocks the red out of the pattern and it ends up looking like a gray liner with the water looking noticeably blue.
    If you want liner that will look nicer longer (besides keeping the chemistry right) try to pick a liner that has a closely matching base color and ink pattern. What I mean by this is if you have the actual vinyl samples to look at flip them over and you will see some liners are inks printed on colored vinyl, some are white, light blue, dark blue, green, tan, etc.
    If a patten has a dark blue base color and dark blue inks then if the inks are ever faded it will fade to the base color. an example of this is
    On the opposite end if a liner has a white base color and dark inks, if they fade it will look very noticeable. example
    Regardless I always tell my customers if you really like a print go with it regardless of the base color. I only mention the above if they are trying to pick between two patterns.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
