Thread: How long can a filter cartridge be cleaned for?
    May 2011
    Miami, FL
    271
    Hello
    I read somewhere that I can simply hose off my Sta-rite Posi Flo filter cartridge and re-use it. I've done that a few times using a lot of pressure, and the crud that comes out is amazing. Wow. I leave it looking fairly white.
    Those cartridges are quite expensive so being able to re-use is certainly a benefit. But, I ask how long or how many times can I keep doing that?
    Thanks
    16,900 gallon inground pool (16x30 with spa bench)
    Sta-rite cartridge filter
    Diamondbrite surface, redone in 2017.
    1.5hp Hayward Super Pump
    Hayward Navigator Pro suction cleaner with V-flex kit
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: How long can a filter cartridge be cleaned for?
    Till it rips, breaks or doesn't filter properly.
    Usually for several years.
    BobinBaltimore's Avatar
    Dec 2009
    Northeast of Baltimore, MD
    116
    What I do is buy one new cartridge per year (since they are so expensive). I note the date on each one. This way, it spreads the cost out over 4 years and I get the benefit of 25% pristine cartridges every year. My filter is oversized for my pool, so I could probably skip a year here or there in the future and still be fine with proper cleaning. Also, I keep the newest OLD cartridge around just in case I get a rip or need a quick replacement.
    25' x 37' freeform, 22,000 gallon saltwater, 3'6" to 6'6" deep, including baja shelf and benches, 120 ft EP Henry retaining wall
    Pentair equipment (CC420 cartridge filter, VS-3050 variable speed pump, IC 60 salt cell, EasyTouch), 200 sq ft pool house
    View our Pool Build - View our Pool House Build
