Results 1 to 9 of 9
Thread: what happens when plaster errodes
    May 2011
    Jackson, MS
    27
    We are renting a house with a pool that has been nothing but trouble. Since the homeowner had it opened in May, we have not seen the bottom of the deep end.
    Right now I am in an argument with my husband about the plaster. When plaster erodes, will that cause cloudiness in the water? I'm having trouble getting our pool to clear up and w hen we brush it, we've noticed that the water around the newly brushed area appears cloudy.
    We are getting ready to call the homeowner to discuss possible problems with the filter and pool maintenance, but wanted to get some opinions first.
    Please let me know if you need any additional information.
    Northern who moved to the south and now has a pool!
    25,000 gallon pool - plaster
    Purex Triton sand filter
    Re: what happens when plaster errodes
    Badly deteriorating plaster can cause cloudiness when brushed. Cloudiness when brushing is also common for a painted pool.
    A full set of chemical readings will be helpful. Both current and past numbers, if possible.
    Support the site
    Emphasis on the "badly deteriorating". Typical plaster erosion will not cause cloudiness until it has gotten quite bad.
    May 2011
    Jackson, MS
    27
    What's quite bad??? It looks awful to me.
    I've attached a photo of the top stair that doesn't have water on it right now, and the tip of the deep end.
    I'm trying to figure out what to tell our landlord. We chose this house because of the pool and it has been so much trouble that I'm beginning to think its something with the actual pool or filter to be honest.
    Also, I have new numbers, but I was battling some algae so my FC is high from a shock yesterday. I had to turn off the skimmers and only have the bottom filter going because I need to top off the pool from a vacuum to waste yesterday as well. I added some muriatic acid last week...guess I added a bit too much.
    FC 13.5
    CC 0.5
    Ph 7.2
    TA 150
    Ch 50
    Cya 80
    On July 20th when I got my test kit, my numbers were:
    FC 3
    CC 0.6
    Ph 8
    TA 160
    Ch 60
    CYA 20
    Yes, that is in bad shape. It is quite likely that plaster dust is coming off of that.
    Your CH level is way too low.
    May 2011
    Jackson, MS
    27
    What do you think we should tell the landlord?
    I think that the surface will need to be redone before you will get the pool to a usable state. What happens if you rub your hand on the surface, does any color come off on your hands?
    It's unusual that there is no tile at the waterline.
    Also, I see that your cyanuric acid went from 20 to 80 in a few days, did you add cyanuric acid?
    Support the site
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    It is important that you have never seen the bottom of the deep end. This alone makes a pool unsafe.
    What is the arrangement with the landlord? Who is to foot the bill for maintenance?
    That top step and some of the bricks make me think that this pool is painted plaster, in which case it will never stop clouding.
    If I were in your place, and I had small bucks to spend, I'd stop brushing the pool and do the shock process including overnight free chlorine test. If you can rule out algae, and not stir up the pool, paint clouding may temporarily settle down enough for you to get to see your deep end.
    You've got either algae or paint clouding or both.
    This is very disappointing of course, but at least you don't own this bad boy. I know what it's like to have to face this sort if thing and be forced to do a refurb.
    Rule out algae or treat the algae and see where you are then.
    Good luck~~
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    I think that Lana537 is probably correct about this being painted, and about how it won't stop from clouding. The clouding can also cause the cyanuric acid test to read high.
    Support the site
